295/70 r18
ttudesperado
Ive got a 2011 Limited with a 3" toytec ultimate bilstein lift with a shrockworks bumper currently with 275/60r20" looking to put on some 295/70r18" w ATX Mojave -24 offset
do you think theyll fit? could i go larger?
What upper control arms do you have? Stock? Then yes a body mount chop as you can't get enough positive caster without aftermarket upper arms.
You're looking at 9" wheels? Why not 4.5" bs (-12) instead of 4"?
I run 295/65x18 on 18x9 -12 with LR uca's. I set my caster at >5.5 then only needed some trimming to fit, no body mount chop and no rubbing. The 4" bs is going to give you more rub in the rear than 4.5 bs.
Good luck
