2nd gen alignment failure...
jgilk1
2nd gen alignment failure... parts to cheap?
so took the truck down to get an alignment... and obviously i knew the upper ball joints and outter tie rod ends were well out of spec... they declined to do an alignment and in turn offered me a $1500 quote with the parts i already knew needed replaced (~$350 in parts and $1200 in labor)... now i hate buying stuff from napa and auto zone due to there lack of intelligence and have yet to check with orillys but while sitting here looking up parts i came across this on ebay
Suspension Toyota Pickup Runner 4WD 90 95 Ends Ball Arm | eBay
the part numbers listed indicate the parts are "moog" brand and i have hears people using there rear springs but i know nothing of there other suspension parts?
before i drop $90 on parts through ebay and another ~$200 /2 hours of time waiting on the alignment for lifetime alignment service package anyone else use any of these "brand" of parts
I use Moog all the time, Its a quality part.
Thats a good deal on parts! If I still had an IFS rig, I would get those as spares!
Sweet deal! Ordered! Thanks for posting that... :whoo:
I am in need of an Idler Arm anyway and could use some outer tie rod ends, the rest will be trail spares.
why i ought to.... i knew better then asking a bunch of parts guys if parts were legit hahahaha
Received this parts kit on Wednesday, I was out of town so I haven't done a thorough inspection yet but the shipping was really quick.
I'll post up some more details tomorrow.
Damn i want one of those kits too. Any idea if it'll work on my 89? manufactured 11/88. And if you haven't done that stuff before, your best tool is gonna be a bigass sledge. **** the pickle fork and pullers.
Hell I just ordered me a set also. I need a couple of those pieces figured Id do it all in one go. Thanks for the post haha.
It should, Suspension for the front on an 89 is the same as second gen. All the parts should crossover.
That is a good deal.
The 3rd gen guys hate Moog, apparently they have an inferior ball joint design for the 96-03 trucks. I ran Moog ball joints and tie rod ends on my '86 and was happy with them.
Heres some pics and details on these parts for you fellas:
All ball joints, pitman arm and tie rods ends are in bags with this marking "OE Brand" and have white stickers on the bags with the nomenclature and MOOG part #s.
Every part includes all associated hardware (bolts, nuts, cotter pins and grease zerks as applicable). Only the upper ball joints and Pitman arm have grease zerks; all other parts are sealed shut without zerk locations.
IMG_0617.jpg~original
Upper Ball joint w/ Grade 10.9 studs and crimped style self locking nuts.
IMG_0620.jpg~original
IMG_0622.jpg~original
Lower ball joint w/ Grade 8 bolts and nylon nuts. Also pictured is one of the tie rod ends.
IMG_0625.jpg~original
Idler Arm has a different style bag and logo for "DLZ Chassis Parts"
IMG_0626.jpg~original
IMG_0627.jpg~original
IMG_0628.jpg~original
Everything seems to be of an OEM replacement quality... For the price, I still think it was a smokin' deal.
I hate to dig up an old thread but I purchased the same parts above. The lower ball joint did not line up. I have contacted the seller earlier today but have yet to hear anything back. I wanted to bump it here in the case that someone else decides to purchase this for their rig. I have a 92 4WD 5-speed 3.0L.
Didn't line up how, got pics? What's the brand and part number?
Attached is the OEM vs the aftermarket pictures. You can see the OE ball joint has a smaller lower "hump" than the aftermarket. The aftermarket one just slightly does not fit the hub. The eBay seller has replied and I will be sending these same pictures in a few minutes.
I had to get one on a whim from worldpac.
I got refunded $19 for the lower ball joints. I'm not sure if they are taking any action to correct the parts they are sending out. I lost a whole day of time and more money spent finding this out.
