2nd Generation Questions
As far as the mpg, I normally sit between 14-16 city, depending on how I drive the 5spd and my granny shift habit. I hollowed my cat now and run a flowmaster 40, also I have a CAI, which I think.I'm noticing a tad more mpg, as well as a lot greater throttle response. Some people have scooted the track back I think. That 4runner should last you a very long time, especially if dealer cared, and only used as a DD.
Welcome to the 4 runner club. I would like to suggest a few items for you.
1. Change the O2 sensor. Your part number for the 3.0 is Denso 234-4052.
Amazon.com: denso oxygen sensor 234-4052
2. Cat converter, Magnaflow part number 91004
Exhaust For Less - Search Results for "91004"
3. Muffler, Magnaflow part number 11255.
Exhaust For Less - Search Results for "11255"
Oil- Pennzoil Platinum 10W-30 or Amsoil XL 10W-30, both are synthetics and can be run up to 7500 miles safely. Walmart usually have the PP in a 1.25 gal jug for 27.95.
Also the PVC valve and grommet may need to be change.
I now have 220,000+ on mind and still going strong.
Others will have more information, can't really go wrong with all the knowledgeable people here.
Enjoy your new toy.
I'll chime in...use Toyota antifreeze. Costs more but will prevent ALOT of future cooling issues!!! Also Toyota thermostats. No other brands seam to work as well.
Thanks for all the helpful info gang!
I recently drove about 215 miles (mostly highway) and refilled with about 12.4 gallons, for an average of 17.3mpgs. Thats more like it...not great, but at least I can see how 20mpgs would be possible now. I usually take it easy under 70mph and shift before 3000rpms.
Now, if I can just get the title in my hand I can start on this repair checklist. I will update this thread as soon as anything happens.
Cheers!
-Scott-
FINALLY!!!
It only took 5 months, but I finally got the title signed and notarized. So, this toy is now MY TOY.
I've been driving the truck since May, and haven't had any problems. I tracked down a bunch of the service records from Mostly Toyota (dba Mostly Auto) in Asheville, and confirmed that the head gasket recall was already taken care of a dozen years ago.
I will read back through this thread to see what leads I can follow up on, but here is what will need to happen to the truck to make it better mechanically:
new complete exhaust ; new brakes ; new rear springs ; new tires ; fix heat ; and fix some window problems. I have a lead on a set of used Goodyear Wranglers, so I might be able to pick those up soon. What about brakes? Seems like Autozone has all the parts for a decent price -- are there any better options?
The motor is burning oil, not sure exactly how much, but it seems like I need to add about 3/4 of a quart every 1000K. Also have a small power steering fluid leak that originates from the under the reservoir - not huge, but enough to drip on everything below.
Shifter pops out of first gear periodically, as soon as I release the clutch pedal -- not during acceleration, only at dead start. This happens about once or twice a month, so I'm not too worried, but I would like to know if this could be a symptom of an old clutch, worn linkage, or something else...? I don't think that I have any record of the clutch ever being replaced, so it could be original for all I know...
Still have designs on making some alterations to the drivers seat frame for more legroom. Also intend to remove running boards and fabricate something else as a step bar. I used the stock luggage rack on a recent trip for my car-top carrier, and it worked well, but I would also like to fabricate a stronger roof rack system that could hold a canoe...or my mountain bike...or a bunch of lumber...but I will start a new thread for all that...
Odometer just clicked past 201,000!!~
-Scott-
FINALLY!!!
-Scott-
Congrats! I'm glad its working out for you. Not sure if you have any other vehicles, but its nice owning a vehicle and keeping that 400 bucks + a month that would normally go to a car payment, and something as useful as the T4R sure comes in handy. As far the leaks and whatnot, most eveyrthing can be fixed without spending an arm and a leg.
FINALLY!!!
-Scott-
I would look into getting rock sliders. You could use them as a step and they also offer rocker panel protection. Almost cheaper than running boards as well!
Sold it today to a local mechanic for $1500 cash.
Thanks again for all the good advice gang. Now I'm driving a 1991 Chevy Conversion van that I picked up from my in-laws. Its not as dynamic as the 4runner, but it has lots of...character...and an indestructable Chevy 350 motor under the hood.
-Scott-
