30k service
Tooltime19
Im preparing for my first 30k service, and I want to know if there are any upgrades or special things I should consider while performing this service such as plugs ect.?
I don't know what the maintenance schedule calls for on the V6, but the spark plugs on the V8 are good for 80k or 100k miles if memory serves.
One thing I would suggest doing even thought the maintenance schedule doesn't call for it is replacing the gear oil in the diffs. The rear diff at the very minimum. When I replaced the gear oil with Mobil 1 synthetic at 30k, I was very glad I did. The original gear oil was very dark and the drain plug magnets were covered with fine metal shavings.
Other than that, there isn't a heck of a lot you need to do to these 4R's at 30k. Maybe change the cabin air filter (they get dirty, quick!). Also, I would lube the 6 fittings on the drive shafts if you haven't done that yet either.
:cheers:
:cheers:
:iagree: and would add do the t-case oil, why not? If it's a V6 it should have spark plugs. Only the V8's get the long-life plugs from the factory.
:cheers:
thanks guys for the info. the v-6 does call for plugs, and I was planning on replacing the diffs with mobile 1 as well. two questions though, first, is their a plug aside from the OEM Denso's or NGK that would give any benefits? Two, with our rear diffs and center locking diff, do I need to add any friction modifier, or is regular Mobile-1 ok?
Lastly GIG, how do you like your Revo's, and how hard do you use your rig? Oh and one last question, what is the rear breather mod and what do i need to do it?
T
thanks guys for the info. the v-6 does call for plugs, and I was planning on replacing the diffs with mobile 1 as well. two questions though, first, is their a plug aside from the OEM Denso's or NGK that would give any benefits? Two, with our rear diffs and center locking diff, do I need to add any friction modifier, or is regular Mobile-1 ok?T
Denso's or NGK's are good. There are many "snake oil" plugs out there that won't do much other than lighten your wallet.
Choosing a NGK or Denso long-life Iridium might be nice but other than that I wouldn't bother.
No friction modifier as the diffs are open diffs with an ATRAC overlay that provides the limited slip. There's no mechanical limted slip involved.
:cheers:
T
Like CJ said, no friction modifiers are necessary. Mobil 1 is good stuff and I feel better that I am running it in all my diffs now. I also agree with CJ and that there are a lot of gimmicky plugs out there. I would probably just stick with the stock plugs.
I love my Revo's. They are not cheap but you get what you pay for. If you do a lot of wheel'n I would suggest at least a LT metric AT tire. I have the P metric Revo which works well. Great on-road manners but tough enough to handle some of the wheel'n I do. I am a moderate wheeler (about 5-10 runs per year) so they do trick. I was actually just watching a video on Bridgestone's website about the new Revo 2. That looks like a sweet tire as well, but there are a lot of good AT tires out there.
Finally, the rear diff breather mod isn't necessary unless you go wheel'n and might experience a water crossing over 6-8 inches. Below is a link with more info about the mod, why you might need it, and how to do it. It only requires about $30 worth of parts and about an hour (or less) of your time.
http://www.toyota-4runner.org/showthread.php?t=123
On the diff breather mod; I'd do it even if you don't plan on fjording the 4Runner. More than one 4Runner has run into rear axle seal issues as they age.
Strictly an IMHO: I believe some of the issues center on the OE check valve in the vent. It allows the axle housing to develop a suction or negative pressure inside the housing when it cools, especially after a long ride that warms the axle. When you start up on your next trip the axle is running with a negative pressure pulling the seals "in" promoting wear. Whether it's an issue or not is for you to decide. I know I parked my '07 overnight (prior to modding the vent) and then checked the fluid level. There was definitely a considerable suction when I removed the plug; suction can't be good.
Just a suggestion...
:cheers:
allcarhistory
