Havik
It can be done.. A true 35 is a little harder, but still possible if you know what you are doing and willing to do some thinking and cutting. It is not for most 5th gen owners.
I run 34.1 now. 35s are in the plans in the next set. But you should not even consider them without a re-gear to 4.56 or 4.88. Also if you are having trouble keeping up on the trails... Think about suspension travel and lockers before jumping straight to 35s. Tire size is a factor that cannot be ignored, but I think a 34 class tire is plenty and is well matched to the 5th gen. I can pretty much keep up with most JKs on 35s.. but 5th gens have their limits...
Some things to consider
- It's all about alignment. Getting the wheels as far forward as possible is key. So UCAs with adjust-ability play a big role.
- BMC is mandatory
- Wheel spacers make things much worse due to the increased scrub radius. Keep back spacing in 4.0 - 4.5 range
- A LCA that could move the lower ball joint forward would be great, but these are only available in LT setups (which will get super expensive fast)
- You will probably need to relocate the washer bottle
- a small body lift (1/2") will help and is easy
- if your truck is for trails (not high speed desert bumps...). don't be afraid to increase the bump stops to run a bit more tire.
Lifts don't really allow for bigger tires (unless you also limit up travel via bump stops...). Its one of the most misunderstood myths.. There are also bracket lifts that do allow for bigger tires, but I don't think you want that.
If you want the cheap route to 35s.
- BCM
- Small body lift
- Be ready to increase bump stops slightly and trim what hits
- Adjustable UCAs with heim joints. These should allow you to get the wheels more forward while maintianing reasonable camber. But you need someone who is willing to dial in the alignment and adjust the UCAs. LR UCAs might also do the trick (but I dont' really trust them myself)
Awesome, thank you!
