4"Driving lights install
Good Job sporty87:thumb3:
That's the way I was originally going to do mine and had set them up. But with my actual fog lights that I have the light pattern is a wide spread out pattern.It was being blocked by the bumper when on the inside.
I take it yours are driving lights and have more of a straight forward beam pattern like the headlights.
I haven't used these at night yet but Yeah it seems the lights have more of a straight forward beam but that is what I wanted and these lights where not too expensive!
Real nice writeup Sporty. Excellent job on the pics too.
You give any thought to cutting holes in the grille?
Thanks,
No cutting thru the grill I want to keep it stock. But if I do down the road the blocks under the lights that raise them up have slots in them so I can slide them forward and then I would make black plastic rings to fill in the odd shaped hole when you cut thru the grill.
I used a piece of aluminum bar stock for mine that I picked up at Lowes. Cut, drill 2 holes, done.
Hey Sporty where did you pick up the spacer? Like Home Depot or Lowes?
Harper, did you need a spacer to install the Piaa 510's?
Drilled a hole down thru the Aluminum bumper,then I used an all thread rod ,washers for height and a 3-4 inch long 1/4" aluminum bar to bring them forward.
Picture040-2.jpg~original
brendaglores
