4Th Gen Chat Thread
Care to elaborate, been thinking on getting one.
best explanation is its a universal speedometer fix. You hardwire it in and can program it to your adjustments of choice. So if you ever swap to bigger/smaller tires you can reprogram.
Everything looks stock still because its all hidden.
http://www.toyota-4runner.org/4th-gen-t4rs/178078-speedohealer-v4-4th-gen.html
He also did a write up after i did it to mine.
I just dont like the scan gauge because its ugly, its another thing to look at, another thing to mess up. I have perfectly fine gauges from Toyota. Making them work to my modification and look clean like OEM is a HUGE thing for me. Scan Gauge was something i always thought of as tacky.
[MENTION=87687]LTDSC[/MENTION]... Yeah, had the speed healer in my favorite box for a while, but, gotten used to the speed change. Was more interested on the scan gauge due to having AT temp, ECT.
Thought there was something I should be aware of as it might blow out other components on our ride.
Thanks Sam.
Thanks Sam.
I love mine. It can tell how many cents you spend per trip. It can give you accurate distance to empty readings after bigger tires. You can read codes and clear check engine lights with it. You can monitor pretty much any reading from any sensor in your vehicle. I've got em in my Corvette, Lexus, and now 4runner.
Hey do any of you guys have issues with the rear hatch staying up in the cold/extreme cold weather? I've been noticing this winter the rear hatch not staying up as well and falling sometimes. At first i thought it was due to the Gobi ladder but i've had that on for almost a year now and didn't have these issues at all before.
probably just worn shocks IMO
This is what I thought too!!
But have come to this conclusion ^
Will most likely do this :
Qty 2 Strongarm 6228 Front Hood Lift Supports Struts Shocks Springs Props | eBay
<iframe width="420" height="315" src="https://www.youtube.com/embed/Mh5rDHv0Gq0" frameborder="0" allowfullscreen></iframe>
I have noticed a huge increase in assisted lift since the cold weather, and then when it warms up around 60 plus, the shocks have no problem. So I would affiliate it to the temperature, I also say that because I thought about looking into replacements OEM's. . . then I lost my credit card with how much they wanted for a set of hatch struts. . .so I think aftermarket is the way to go when the time comes.
my .02 cents
right part number in the link? i need to replace mine badly
Yes sir...
This Listing is for 2 Supports which fit the Following Applications:
2003-2009 Lexus GX470 Base Sport Utility 4-Door Hood
2003-2009 Lexus GX470 Limited Sport Utility 4-Door Hood
2003-2009 Lexus GX470 SR5 Sport Utility 4-Door Hood
2003-2009 Lexus GX470 Sport Sport Utility 4-Door Hood
2003-2004 Toyota 4Runner Base Sport Utility 4-Door Hood
2003-2012 Toyota 4Runner Limited Sport Utility 4-Door Hood
2003-2012 Toyota 4Runner SR5 Sport Utility 4-Door Hood
2004-2012 Toyota 4Runner Sport Sport Utility 4-Door Hood
Yes sir...
perfect, gonna get a pair soon. my hatch groans when i open it lol
Winter is hell on struts. Especially if they're worn a bit. my guess is the extra ladder weight combined cold Temps are the cause. Gas struts are more prone to failure in very cold temps. I'd wager that once the weather warms up again they'll work just fine. if the temps drop below 15 F I usually have to help the hatch a bit but it usually still holds at the top. I also don't have the added weight of a ladder though. Just the nature of gas struts and cold weather....
my .02 cents
Yes sir...
Great guys thanks for the feed back. I will see how they are after it start to warm up a little bit and if there still having problems then i'll order a set of tho ones you posted above. It's definitely been annoying though in the extreme cold having to load and un load the back while the hatch won't stay up.
[MENTION=25740]awdjunkies[/MENTION] These will still work for the rear hatch even though it says (front hood struts) Thanks,,,,,,,, Nevermind i just watched the you tube video, i didn't see it before:thumb:
Think I've decided the route I want to go with my T4R. Hopefully I can build a build thread this weekend and then actually do a little 4runner building next month...
