4th Gen Exterior LED Light Options and Ideas-- Post 'em up!
auxbeam 4d 20w pods on CBI ditch light mounts
20160122_162211_zpssrqqrcju.jpg~original
20160131_214713_zpsw8di4hpn.jpg~original
20160131_214614_zpsphav9eqn.jpg~original
20160130_165225_zpst3xbmexf.jpg~original
20160129_231258_zps2aeyl6ed.jpg~original
Looks GREAT!
Led Light Bar Install
That looks great. I am trying to do the same thing, but I have not been able to get the front bumper off so that I can mount the light bar. How did you mount your lightbar?
Who needs stealth mounted? I just replaced the grille and did flush mounted :bounce:
20150823_155938_zpskmbla4up.jpg~original
20150823_155942_zpssub1quad.jpg~original
20150801_191452_zpsdh9h2ocz.jpg~original
20150801_191653_zpsfnewvubm.jpg~original
Lightbar mounting
I have the brackets, but my drill won't fit into such a tight spot. I couldn't get the front bumper to come off, so anybody have suggestions on to do it with the bumper on?
Updated my 04 headlights to 06. Installed Baja design squadron Pros in the high beams. Added morimoto switch back halos. Morimoto led low beams. Also have squadron pro ditch lights.
Sent from my iPhone using Tapatalk Pro
I did not remove my bumper to install the bracket for this light bar. All you need to do is remove the bolts to the crash bar and install the bracket and put the bolts back on. I used the end of a jack handle as they are on tight. I used a Dremel tool to cut the plastic grill hole out. Not hard, just take your time.
How did you mount the Squadron Pros in? And how did you wire them up to work with the OEM switch.
Looks amazing. I have yet to see halos that I like on a 4th gen until now. Making me reconsider adding them in
How did you wire it all up? I cut mine out today but due to torrential rain on Kauai i had to stop there.. damnit
I had a shop do the wiring since I'm a little nervous about handling that sort of thing. I bought an FJ auxillary switch and pigtail, and put that in one of the center console blanks.
Bunkstaff
