4x Innovations Rear Bumper with Swing out PICS?
thanks for posting the pics! your truck looks great!
i'm planning to buy that exact rear bumper combo very soon so your pics just confirmed the deal for me.
PLEASE post more pics when you have time.
how was the install?
Install was straight forward. You get a bag full of nuts, washers, bolts, etc. but when you start assembling parts, it will all make sense. Adam at 4x Innovations was just a phone call away when I had any questions. You will definitely need a couple of friends to hold the bumper up to the frame while you screw the bolts in. I gotta tell ya, this thing is over engineered, no rattling what so ever. It is rock solid.
Finally got around to uploading some pictures of my bumper I picked up a couple weeks ago. Construction and workmanship is awesome! Adam and the guys at 4xinnvotions did a great job!
[/URL]~original[/IMG]
Ok guys, the time has come. My 4x Innovations rear bumper with swing out is finally on. This thing is awesome and well built. Customer service is top notch...thanks Adam! I'll also post a pic of my front CBI bumper, which is also top notch. FYI, I had them powder coated silver to match my cladding. Enjoy guys.
do you have 33's?
Very late to the party...
Both have 33's, 1" bl, Sonoran Steel rear body mounts.
Adam was very easy to deal with by phone.
P4199381_zps1cl3gkqa.jpg~original
They fit better with my husband's stock flares than my trim, but my mud flaps are just the right width to go perfectly.
P3209326_zpsntfgtmct.jpg~original
The view...only a little taller than the dog crate....
P6219792_zpsmtpst79y.jpg~original
Sorry, it's bright outside...
P6219795_zps22xsg4jd.jpg~original
How does everyone like their bumpers after having them for awhile?
Any issues with tire wobble on the interstate?
Is the latching mechanism still solid?
Does the gap between the bumper and hatch floor bother you or get in the way?
I'm seriously debating this bumper because of it's price and it looks very stout.
We've had ours for one year now so maybe not the best example. So far I am very happy with them. We wheel mild to moderate and they are daily drivers as well.
I am not noticing tire wobble on the interstate...some when off road, not much. I'll have to hit the highway again and stare at it, mostly it sits back there and behaves itself.
Latching mechanism is still solid as can be. The husband managed to bend the pin that keeps the swing-out open on an off-road trip, but Adam replaced it for a reasonable cost. It did still work, just was missing half the handle and was canted. All phone conversations with Adam have been pleasant, just don't (in my limited experience) email him if you're in a hurry. Call.
I actually take advantage of that gap. There's some things I store behind the bumper that the gap makes it easy to get to, like the anderson connector and the trailer connector and the air bag shraders. The dog jumps in and out on his own without a problem, though if he was the clumsy sort I'm put him in myself....there is a potential for leg damage there for less coordinated dogs.
I would recommend the Sonoran Steel rear body mounts, keeps the body flex down and a lot less body to bumper contact. They solved that issue for us.
Thanks for the response [MENTION=5345]habanero[/MENTION]
Mine is a DD as well with some mild wheeling also, nothing super crazy. Good to know about the latching and no wobble. I didn't think about that with the gap. I would probably have a plate bent up at a local fab shop that bolts into those factory holes for the brackets.
The Sonoran Steel mounts and a set of OME 861's are on my radar as well if I do go with this bumper.
I've been wanting to call Adam and talk about turn time and a little custom fab work I want to have done on mine.
Would you be willing to grab a couple measurements from yours?
I'm wondering about clearance on my rear ladder with the frame for the tire carrier and the tire.
The measurements I specifically need are:
The space between the hatch and swingout at the bottom of the hatch where it is pretty much vertical, right before the body line that starts to curve up.
The clearance between the tire/frame where it goes over the license plate frame. This is easier to show with the picture below.
I circled the two places where the frame/tire might go over the license plate bezel and drew a red line along that body line I was talking about. Basically looking for anywhere the tire/swingout may interfere with the ladder. It LOOKS like it will clear, but I don't want to spend $1k+ without knowing.
EDIT: And could you maybe post a pic of yours from straight on behind like the picture I posted? Thanks so much!
No worries, I'll get all of the above in the morning where there's some light. Will put in in this post.
Ooh bananas! It's soupy out there!
[MENTION=116387]Unner[/MENTION] using your picture as a guide...
Left side, showing support for swing-out that rests on top of the bumper:
To the vertical part of the hatch (under the swing arm):
P6239801_zpscwlgovvw.jpg~original
Laid the ruler on top of the swing-out bar to measure straight across to hatch:
P6239802_zps22hcxzss.jpg~original
Right side, where the bar for the tire carrier meets the swing-out. The swing-out is angled so this side has tighter clearances:
P6239804_zps3tgo0fof.jpg~original
P6239803_zpszeisxcmz.jpg~original
Tire...BFG A/T KO2 lt285/75r16 with not a lot of wear...flat edge on widest part of tire to the plate surround:
P6239796_zps9kprverz.jpg~original
left side of straight edge showing end of what widest part of tire covers:
P6239797_zpslvuex9vh.jpg~original
And measurements as best as I could get them:
Top:
P6239798_zpszkbtw4vs.jpg~original
Bottom:
P6239800_zpsgd5ung9t.jpg~original
And butt pictures of both trucks, same tire and tire size w/different rims, as straight on as I could get:
P6239809_zpszodfmduq.jpg~original
P6239808_zpsg8lpx9ke.jpg~original
The swing-arm support is directly under the "R5" on the SR5 emblem in the above pic, approximately another inch inward of the t-handle on the latch.
I've got some time today if you need more.
I've got 2 out of 3. Looking to complete the set soonish... This bumper has been through hell for the last 3 years. It's rammed stuff, blazed trails through thickets and been tooth rattling yanked and is still strong as ever. If the rear is half as good as the front, I'll take two.
77F51720-60DD-4C37-B11D-E72CF8F951F1_zpsxcuqy2ed.jpg~original
Had mine for 2 years now and it's still SOLID. Zero rattling and shaking, this thing is over engineered. The only thing I regret is not getting the 1" BL option but at the time I bought the bumpers, CBI and 4x Innovations did not have that option. The gap isn't bad at all.
H.Sikina
