5th Gen Wheel & Tire Thread
I just got a stock 2015 sr5 and was looking to get some beefier tires on it. i cant decide between the duractacs or the Bf KO2s. Also I can't decide what size to get whether I should get 275/70/17 or 255/75/17.
Wheels: Stealth Custom Series "Stealth 6" 4.30" B.S.
Tires: BFG KO2's 275/70R17
UCA: ICON
Lift: Icon Stage 2
Rubbing: Zero
Body Mount Chop: LOL
Fender Lining Mod: Nope
Nice build! Those stealth wheels are purrty. What lift do you have installed? :clap2: :nicethread:
Great thread for people inquiring about tires/wheels fitment and lift. Since I get a lot of pm about my setup, I'll post it here.
BR Sidewinder 20x9 -12
Cooper ATP 275/55r20
Stock suspension
Rubbing on reverse
Great to see. I JUST purchased my first 5th gen (my 3rd gen was killed by a massive hail storm). I have the same Magnetic Grey LE and not sure what to do with the 20" wheels on the LE. I have my old 17"s off my 2001 with new KO2s but like the 20" wheels...
2015 blizzard Pearl LE 4x4
275/55/20 GY adventure all terrain
20x9 sendel s36
+10mm offset
Stock suspension
Inner liner fender mod
No rubbing
Fuel Assault wheels
I got some Fuel Assault wheels. The guys at good year won't mount my tires because there isn't enough of the stud sticking out to thread the lug nuts on. Does anyone know if the et extended lug nuts will work or do I need to get the longer studs? I did research and found that I may be able to do either, but just looking for anyone that has experienced this and what you went with and the part numbers if possible. Already ordered the et lug nuts but if those don't work I'll order the longer studs. I have a 2016 SR5 so I'm not exactly sure which studs would work. Sorry for the noob questions but it's frustrating having the new wheels and tires just sitting in the garage. Thank in advance!
Where did you buy these wheels from? If it was me, I would return the wheels and tell them that the length of available thread on the wheel studs is not sufficient and quote Goodyear. I personally would never run wheels with universal lug patterns on a wheel. That's 12 holes where there should only be the six mounting holes necessary for your 4Runner. I think they made the mounting location for the lugs extra thick due to removing so much material for the extra set of universal lug pattern. 12 holes where there should only be 6 holes in a critical strength area of the wheel right next to the hub. Hope this makes sense.
Thanks! I'm running an Icon stage 2 with steel UCAs.
I have to say, your icons and photos in your signature are really annoying. Sorry, I'm not usually one to complain but for example on this page, the photo gallery has 25 images, only three are wheels and tires, the other 22 are your icons. It would be nice to flip through just the pics of wheels and tires. Sure would appreciate it.
Sent using Tapatalk
Sent using Tapatalk
Sorry, I can't control how Tapatalk displays this forum...
Anyone have recommendations for low gloss tire shine? I don't want a "wet" look, just want to get rid of the "ash" look.
Aerospace 33 protectant. Get it on amazon. There's some other threads here about it. It's a great 'low gloss' and non-slimy non-greasy product. Read up on it.
Actually you can control it but are obviously choosing not to. It's not impressive, definitely not cool and the fact that you would willingly choose to do something that is annoying to other members of this forum speaks loudly.
Method machined double standards, 17 x 8.5 0mm offset.
Just got these last night from my buddy at Method and test fitted them this morning on my 2016 SR5 4wd.
Fit perfect, no spacers, clears calipers.
Only tried one wheel with a full spin, going to risk it and assume the rest will also clear.
Sweet! Look forward to seeing them mounted up [emoji106]
Sent using Tapatalk
So last weekend I became a member of the 5th Gen T4R’s.. I ended up getting a 2016 4x4 SR5 black 3 row seats ..
Just Wanted to share my wheels and tire package with you guys ..
20x9 with +20mm offset / 275/55/20 Nitto Terra Grapplers G2
17x9 level8 mk6 gunmetal
-12 offset
BFG ko2 285 70 17 E
5100 2.5" front 1.5" rear lift
Fender well trim mod
No BMC
