Cali 4runner
Member
Awesome, just awesome.
Tired of shifting gears? How did you decide on the 3.4?
I didn't see if you needed to do any rust protection to the frame? Is that an issue where you live?
Nice work! Any plans on swapping for a solid front axle? I’m just getting started on my project (87 runner) and I’m debating on whether the SAS is worth the work.
4Runner 4wd 5VZ-FE pan vs New T100 4wd 5VZ-FE Oil Pan, and strainer to clear the IFS
https://farm8.staticflickr.com/7801/33290890788_68fe4cf2ca_z.jpg[/img
[img]https://farm8.staticflickr.com/7816/47165956541_feb7442f8c_z.jpg
After removing the dipstick hole plug in the side of the block, and installing a T100 tube and dipstick I needed to plug the oil pump housing hole where the original 99 4Runner dipstick was located. I used a Dorman 555-007 13.7mm freeze plug.
I'm using Chilkat Designs conversion motor mount brackets for the swap. The original mount was .190" behind the A/C compressor bracket, and the new much beefier conversion brackets were substantially thicker. This was going to create an issue with alignment on the other bolts for the compressor bracket. I just used a Sawzall to remove the material on the comp bracket, and everything lined back up perfectly.
Tinman1985 said:Where did you find the dorman freeze plug? I just finished my 3rz swap and looked all over for one. I currently have 2 dipsticks until I could find one.
