89hatcher's Sunfire Red Pearl Build!!!
here's a little update. I ended up snapping a stud on the front right hub so I ended up replacing all 6 on that hub.
I also ended up changing my ugly crappy battery terminals.
replaced the hex bolts with some stainless allen bolts I had laying around.
and heres how the height looks as of now. hate it or love it. I love how the rake is on it.
debating if I want to install my 1 inch body lift I have on the side. yes or no?
I also like the rake [emoji1360] I hate how the short rear links pull the axle so far forward, but oh well.
No way would I install the body lift with that tire size. It already has a ton of fender room- no reason to increase that. Just my opinion, of course.
was debating on the body lift because im already running 285/70/17 tires. might just wait till later to install it maybe if I decide to go 35's.
front suspension set up
What front suspension setup did you go with on your build? Thank you for your time
If it were mine, I would say it's probably tall enough.
Looking really FINE! I also subscribed as my old 98 is the same color.
I wait to see all that comes next......keep up the excellent work!
Beast
This thing is looking beastly. I think you mentioned it in the thread but what size tires are you running?
I need to replace the lower ball joints on mine as well but i'm nervous to try and break the rusty bolts off.
That sunfire red is awesome!!! Can't wait to see more.
patnewton
