1985taylor1925
Senior Member
"Jitters" Mod/Build/Maintenance Thread
Consider this the thread for my truck. Call it my "build" thread, "mod" thread, "maintenance" thread, whatever. It's going to be a record for myself of what Ive done so I can keep track of maintenance and such. So here we go . . .
"Jitters"
1998 Black SR5, 4x4, 3.4L, Auto
Purchased in Ft. Collins, Colorado on 8/3/10 for $6000 with 161000 miles, 100% stock
My objective with my truck is to make it as nice as possible (exterior, interior, mechanics, functionality), not necessarily "build" it. It's my daily driver, and probably will be for a while. My primary driving is highway for work, so building a rig designed to perform off road would be great, but simply wouldn't be practical for my needs. What I want is a truck that is extreamly healthy and well maintained, performs well on any road conditions or terrain, does everything I need including tow small loads and take me on my many adventures, can be trusted to drive cross country and back, and has a look that appeals to me.
Here's what I've done thus far.
As of today: Updated 8/30/17
242000 miles
Last oil change: 248500
Mods and Add-on's
Exterior
- Clear corner and bumper lenses
- LED tail lights
- Pre-fatlip bumper painted OEM black (purchased from blcktpgsr)
- Rear bumper ends painted OEM black (purchased from BanditRunner) thanks BanditRunner!
- Front grill flat black (just repainted)
- Sotashi mod with Tundra Toyota emblem
- Liscense bezel painted OEM black
- Skid plate painted aluminum metalic (just repainted)
- Westin in channel vent visors
- Updated SR5 flares to wide sport flares
Interior
- Interior dash trim painted Rust Oleum semi-gloss black
- Husky floor liners, front, back and cargo (one of the best purchases I've ever made)
- Kenwood KDC-BT955HD Head unit (AUX, bluetooth, HD radio, CD, etc)
- Infiniti Reference speakers
- Alpine power pack amp
- CNC cut stainless steel "4RUNNER" door sills
- Custom made cup holder! Best mod ever
- Rattle Trap and Noico sound deadened throught the entire vehicle (front and rear floor, hatch, all 4 doors, hatch door)
- Closed cell foam decoupler on many of the interior panels
- Limited leather door panel swap (purchased from DeathCougar)
- Auto vinly center console cover
- 99 center console swap for cup holders
- Steering wheel cover
Suspension/Drive Train
- (Rear) 99 Coils, stock shocks
- (Front) 99 coils with Tacoma Bilstein 5100's on lowest setting
- Safari LTD Steering Rack
- Sway Away poly steering rack bushings
- Sway Away poly front and rear sway bar bushings
- @MStud front adjustable front links
- Rear diff breather mod
- EBC performance brake rotors and pads
- 2016 4runner wheels mint condition
- 265/70r17 Cooper Discover AT tires @ 230k
- Sway away lca poly bushings
Engine/Performance
- "Hole in the air box" (deck plate) mod
- ISR mod
Lighting
- 99+ glass Headlights from Certifit
- Hella Micro DE custom mounted fog lights
- Interior LEDs (center consol, map lights, speedo and odomoter indicators)
- LED aftermarket tail lights
- Clear corners and bumper lenses
- Phillips super white headlights
Maintence/OEM parts
- New rear cone bump stops @ 165k (taken off when lc coils installed)
- Moble 1 high mileage synthetic and OEM oil filters every 4 - 5k
- OEM air filters every 10k
- OEM Injector #3 @ 165k
- OEM spark plugs @ 165k
- Amsoil synthetic rear diff oil @ 166k
- Tranny oil full flush and refill @ 175k
- OEM fuel filter @ 173k
- OEM inner tie rods @ 170k
- OEM tie rod ends @ 168k
- OEM upper and lower ball joints @ 170k
- OEM remanufactured steering rack @ 173k
- Seafoam in oil and pcv valve @ 186k and 190k
- New Denso Radiator and Toyota Red coolant @ 187600
- OEM remanufactured drive/pass cv's @ 189300
- OEM steering column shaft sleeve bushing @ 189300
- Replaced steering intermediate unit with lower mile (107k) unit @191000
- OEM reman cv's (again) @ 203000
- Reman alternator @ 212000 11/1/14
- New Safari LTD Steering rack @ 220000
- Energy suspension rack bushings @ 220000
- New Beck/Arnley upper ball joints @ 220000
- New OEM inner tie rods and rod ends @ 220000
- Lower mileage steering shaft intermediate unit (to rack) @ 205000
- Amsoil front diff oil @ 215000
- New OEM front wheel bearings @ 220000
- Greased all drive shaft fittings @ 22000
- OEM spark plugs @ 225000
- EBC brake rotors and pads @ 237500
- Removed all carpeting and seats and carpet cleaned to remove all stains
- Eastern Cat converter @ 237500
- OEM rear u joint @ 237000
- Sway Away lower control arm bushing @ 243000
- OEM rear shocks @ 243500
- OEM valve cover gasket @ 244500
- OEM spark plugs @ 244500
- OEM intake manifold gaskets @ 244500
- OEM passenger lower ball joint @ 245000
- OEM used cv axles @ 245000
- OEM inner tie rods @ 245000
The Dream List
- Low mileage engine swap
- Turbocharger
- JAOS spoiler
- Wide flares color matched black
- Projector retrofit
- Full length roof rack
- Keyless entry and alarm
- Remote start
- Tundra brake upgrade
- Re-gear with 4.3
- King coilovers
- Watts linkage in the rear
- Leather seats/covers
- Full undercarriage restoration
- Upgrade rear door speakers
- TRD headers
8/5/10
Here it is the week I bought it. Running boards still on.
Running boards off. Amazing how just removing running boards gives it an instant lift.
About a month ago I installed KYB gas shocks. Tires are brand new Goodyear Wrangler RT/S 265 70 16. Ive learned that tires for this vehicle are significantly more expensive than for my old Ford Taurus!
I bought the Husky liners to protect the carpet. They're a great investment here in Wisconsin, or any mid-west state where they use salt during the winter. These liners are awesome! Also have them in the back. And plan on getting the cargo liner eventually.
Last week I brought it in to a Toyota service center and got new rear coils and cones via the factory recall on the original springs. Nice freebie.
More to come
"Jitters"
242000 miles
Mods and Add-on's
Exterior
- LED tail lights
Interior
Engine/Performance
- ISR mod
Lighting
Maintence/OEM parts
The Dream List
- Turbocharger
- JAOS spoiler
- Remote start
- Re-gear with 4.3
- King coilovers
- TRD headers
8/5/10
More to come
