Did this fix your int vibration???
Yes it did
First post.
Just wanted to say thanks to everyone for the help! I have 1999 V6 4WD 4Runner with 205k miles, both rear seals were leaking.
Dealership wanted $1,200 just for labor to replace the seals and press new bearings. I was able to find a local machine shop that pressed the new bearings onto my axles for $67/side. Went with the method recommended here; retainers were reversed and moved 2MM inboard. The original factory seal sat dead center on the retainer, grease test of the new seal design had it on the edge as shown on the photo.
I rented a seal driver set from Autozone (item 27119) and a rubber mallet to set the new seals.
Purchased Toyota OEM for the seals, aftermarket for the ABS ring, NSK bearings (still Japanese) and aftermarket retainers.
Only thing I noticed were on two of the four aftermarket retainers, the machined surface was so rough it would have chewed up the new seals, ended up using them to retain the bearings. Other two were fine, same finish and diameter as OEM. Got the whole set off eBay $105.
Total DIY cost was just shy of $300.
Attached a photo that I gave to the machine shop in case anyone else wants to use it.
Only 1,000 miles so far but no leak.
Thanks again.
Yes it did
Dude, what you need to do is take your truck back to them and insist they do the grease test right in front of you. This is what I did when my local Toyota dealership screwed up the job and I was leaking on my driver side in less than 5000 miles. The tech who did the job on my truck did not even know what a f#cking grease test was. So, another tech watching the whole show told him what he had to do. When he pulled the axle back out the grease test showed the lip of the seal was barely riding on the polished surface on the retainer, right on the edge of the bevel. At one point, one of the many techs watching what was going on told the tech that did the job on my truck that I just schooled him. This goes to show that a DIY mechanic can often know more than a paid mechanic because of forums like this that share information.
[MENTION=102606]infamousRNR[/MENTION], [MENTION=148218]JZiggy[/MENTION] and I recently did an axle seal job on [MENTION=148218]JZiggy[/MENTION] non-abs rearend. We confirmed without a doubt that following [MENTION=78997]Drcoffee[/MENTION] suggestion of flipping the retainer around was absolutely necessary to get the lip of the seal riding in the center of the polished part of the seal retainer.
What many techs still don't understand is they can't follow the FSM specs for the placement of the retainer anymore. Toyota redesigned the axle seal at some point in the past and now the lip of the seal sits 2mm more inboard than before. If you follow the FSM spec, the lip of the seal will be barely riding on the polished part of the retainer.
With the Non-ABS rearend, you have to press the retainer all the way against the bearing to get the retaining clip in place so you can't adjust the retainer position to get a better mating with the seal. The only choice we saw was to flip the retainer.
With the ABS rearends, you have a second inner retainer and an ABS gear. The inner retainer is what connects with the axle seal. This retainer in it's original orientation can be moved a little more inboard to mate up with the seal better but then it comes very close to rubbing the inside of the axle housing. Flipping the retainer again seems like the best choice to get a better mating of the seal and retainer and keep the retainer from rubbing the axle housing.
We filmed the Non-ABS job and we're going to hopefully film an ABS one soon. We missed filming an important part of the pressing procedure so we're going to wait until we film the next one so we can add that missing footage so the video will be complete and not leave people guessing how we did it.
TAKE YOUR TRUCK BACK AND TEACH THEM SOMETHING ABOUT OUR RIGS. Your efforts will hopefully avoid the next 3rd Gen owner that visits their shop for an axle seal failure from going through the same bullshit. Good luck and please report back what the result end up being.
When I inevitably get around to this, how can I assure they do it right? I mean I can't drive it to them and do the grease test myself. The grease test involves putting it back on completely and putting back in the hub right?
Also, I asked a machine shop recently over the phone about doing it this way, and they said they'd do it to the FSM specs due to liability.
Sorry for the late response. I had an ongoing intermittent vibration that I could not pinpoint. Finally someone had mentioned bent axle can cause that. Sure enough, mine was out by 10thou if i remember correctly. Checked the runout with a dial indicator, per the FSM. Replaced axle with a junkyard unit.
I think measuring from the "polished edge" is not the best idea. That isn't a set dimension from the face of the axle as far as I know - and there could be variances in how much material is polished from the factory, not to mention aftermarket manufacturers. Measuring from here is taking a chance... you might get lucky... you might not.
The Toyota FSM shows where the ring needs to be measured from the face of the axle.
Happy thanksgiving everyone! My seals are holding at 225,000.
I have an unused bearing puller tool for sale in the sale section if someone is looking for the press tool to do this job. You can buy this tool and a harbor freight press for less than the cost to let toyota do the job wrong.
http://www.toyota-4runner.org/sale-t4r-items/247219-fs-rear-axle-bearing-puller-tool-new-nw-indiana.html#post2849695
Measuring this way is fine. My meaaurements will vary from yours. That is why I stress using the grease test method. Dont assume my numbers will be the same for you. But you need a point of reference when determining how far to shift the retainer and that place is easier than any other.
If you think about the BS excuse that axle is bent, ask how this would create the vibration. The axle is supported by the splined end at the pumpkin and the hub by the bearing. A little bend isnt going to give you that kind of vibration at the speeds the axle is spinning. 10 thousands out is frickin imperceptible. Dont waste your money.
What kind of vibration specifically? I have vibration and steering issues and an alignment shop told me it's my rear end. So I'm curious what your truck's symptoms were
Did you really just ask how a bent axle would create vibration?
You may not have realized that I had already fixed this issue prior to my first post regarding it. The flange runout was 10 thou outside of the limit per the FSM. That was the problem.
If the flange is bent, it will cause a vibration. But not cause an oil leak....UNLESS, the oil seal is sitting right at the edge of the bevel of the retainer. I was referring to the axle shaft.
Hey, there is nothing wrong with sticking your head in the sand and holding the FSM up as the bible with a faithful reliance that all will be well. But for the rest of us who want to make sure the seal is properly position, the grease test is the GOLD standard.
I just re-did the seals for the forth time in 3 months.
Feel free to share your thoughts.
Have you pulled out your ABS sensors to check for leaking yet? Check back when you do.
Actually, its 2mm. Per the FSM.
Interesting thread.
FWIW: I replaced my bearings and seals on 06-24-08 at 154,500. I took it apart today to investigate for a bent axle shaft (and it is!), but thankfully still no leaks. Current mileage is 234,028... so 79,528 leak free miles.
Factory measurement still works --> http://www.toyota-4runner.org/2152324-post29.html
