A question about my new 2012 4R SR5
jamesq
Hello everyone, I am new here, just got my 4R. Now I have a few questions
1. Is the rear parking sensor very sensitive? Mine I need to go rear very slow and very close then the sensor has bi-bi sound. It seems useless with this sensitive level..
2. Every time when I ignite the car, turn the wheel(left or right), there is a one-time scratch sound. Just one-time every ignition. Is it normal?
3.Brake pad scratch noise.
Please help! Thank you!
For #2: are you stationary or are you moving when you turn the wheel and hear the scratching sound?
Also, when I read "ignite the car" I imagined something like this :flamethrwoer2:
Hello Eagle! Thank you for your reply! :)English is my second language, so :redbrick:
When I move forward, the first time I turn and turn back the wheel, the sound appears.
For #1, I think you can have the Toyota Techs adjust the sound level and the sensitivity of the backup sensors. Someone might be able to better answer this since I don't have backup sensors. I remember reading something about the sensors in the Dealer customization thread PDF.
#3, does the noise happen all the time or only if you leave the car sitting for a few days? Maybe the rotors are sitting and a film of that rust develops. Usually when you use the brakes the noise goes away. Or if this is a new car it might take time for the rotors and the pads to break in.
edit:
looks like the volume is just adjustable and it is set at MAX sound.
http://www.toyota-4runner.org/5th-g...s-dealer-can-program-2010-toyota-4runner.html
Hello Eagle! Thank you for your reply! English is my second language, so
edit:
Hi Mason, thanks for your suggestions
1. Sometimes the sensor works normal, sometimes it doesn't sound at all even when I am very close to the obstacle.
2. Every morning when I start the car, I can hear this sound, it seems from
under the wheel, and my hand can feel a little bit scratch shake. After that, however you turn the wheel, there is no any sound. If I park for an hour and start the car, the noise comes again at the first turn.
4Runna4Rumma
