I ordered the part number in this thread, and got a blue thermistor. I went to replace it and found a black wired one installed but no carrier to twist to remove. I wasn't sure how to uninstall it on a 2007 but I'm guessing they are different than the early 4th gen's in this thread because it looked nothing like described. I should have taken a picture to put up and will later on if anyone can tell me how I'm making this more difficult than it needs to be.
Yep, this only applies for 03-05 so I have one for sale OEM pn 8862535050 new in package if any needs one. Fits 03-05 only!
Hello,OK, I got this changed finally and it did solve the excessive cycling problem. The AC is colder than it has been in years, so the failure mode of this piece may be gradual.
The thermistor (thermal variable resistor) is used to tell the control unit that the evaporator is cold enough to cycle. Typically clutch cycling for temperature control is used in conjunction with a fixed orifice tube instead of an expansion valve.
The thermistor should be suspected if you have excessive cycling, but normal pressures as did the OP.
To test, remove the glove box and locate the connector on the left. It has two small wires. the wires to the thermistor are in a plastic sheath. On my subject vehicle the original sheath was green and the replacement was blue. If you disconnect the connector, the compressor won't run at all. If you jump the two wires, the clutch won't cycle and the AC will be too cold. If you can achieve cold air by jumping the wires, you probably have a bad thermistor.
The part # was 8862535050 and it listed for $16.39 at this time. Plugging the new part into the connector also made the AC run excessively, because the thermistor was not in position to sense evaporator temps.
To replace the part, Do NOT Pull on the wires! They will just ball up in the evaporator case and complicate things.
The thermistor is held into the evaporator case, and held in position by what I will call a Thermistor Carrier. I get to name it apparently, because Toyota does not list it in the parts diagram. It really should come with the new thermistor, but does not. The carrier is about 6 inches long and guides the thermistor to just the right spot inside the evaporator case.
From the outside, it looks like a black plastic plug right where the thermistor wire goes into the white evaporator case. It has two prongs that lock it into inside of the case. I don't know how it is supposed to come out, EDIT NOTE: Fuzzy fingers says to turn this carrier CCW 1/4 turn to release it.....but I just pried on this plug until one of the prongs finally broke.
Then I was able to snake out the carrier. The carrier has clips to hold the thermistor and wire in place and it will be obvious how it goes when you look at it. I put a wrap of electrical tape in a couple spots to make sure the thermistor stayed in place when reinstalling.
Sorry I did not get photos. If the OP wants to hit me up since we are locals maybe I can help you out and we can document better.
Forum won't let me create a new thread yet, so I will put this question here.
I am having a problem where whenever I am stuck in traffic or not moving very much, my A/C Compressor seems to cut off, and the cabin gets warm quite quickly. Is there anyway to override it so it will always stay running?
It seems I have some AC issues with my new-to-me 2003 4Runner. Mine also seems to be short cycling where the compressor will kick in, the AC will be quite cold, and then it will cut off for long enough for the air to start warming up until it cuts on again.
Here are some temps I took this weekend:
71 ambient air temp, car had warmed up inside higher than ambient (forgot to take the inside-cabin air temp).
Compressor cycling on - 42 degrees
Compressor off cycle - 52 degrees
These temperatures would keep going back/forth during the course of a minute while the compressor cycled on and off. AC light does not blink.
Things I've tried to fix the issue:
- New AC relay from Autozone (original one was bad, had a blinking light)
- Removed/cleaned the inside temperature sensor near driver kick panel
- Had system vacuumed/recharged at Toyota dealership and filled with dye. They could not find any leaks, and I can't either with a UV light. Evaporator drain tube is not leaking dye, although I don't see it draining much at all.
- AC condenser does not have any caked-on grime
Do you guys have any suggestions? I've read through all of Fuzzy Finger's posts on his AC troubles with the same issue, and it looks like he replaced just about everything with no fix. I'm just not sure where to start at this point since I covered most of the easy fixes besides trying the thermistor.
Did the Toyota dealer not find any issues, what did they say after charging the system?
If the Toyota dealer could find any issues, I'm not sure what to tell you, have you checked the AC compressor clutch, is the engaging and staying engaged?
My first thought when starting reading your post was a bad thermistor sensor, did the Toyota dealer not check it?
Also you said you cleaned the cabin temperature sensor but stated it was near the driver's kick panel, not sure what you're calling a kick panel but just so you know the sensor is right below the ignition switch behind the little slots in the plastic trim.
Have checked the sight glass while its running? It sounds like the expansion valve the way it acts. Runs, freezes, thaws, runs again. Repeat. I assume toyota used gauges when they recharged it. But the manual clearly says to use the sight glass for an accurate fill. Over filled is just as bad as under filled.
Do you see liquid? Or does it look empty? Shine a light into the sight glass with the AC off first, then on and note the difference. If its always liquid its over filled. A bad evaporator is a leaking one.
