Add a circuit USB charger port
simple
Senior Member
Now, I'll be the first to admit, this mod was probably 90% unecessary but I enjoyed it.
I grounded the plug on the bottom bolt in this pic above.
I cut a little too much, but ended up pretty clean. I'll end up writing the 2 fuses I had to cut off the placard on the bottom for later with a sharpie. I ended up plugging it into the "acc" accessory fuse.
c8eb8db6-bae1-4238-8bba-379de44f093f.jpg~original
I routed the wires over the knee airbag. I just put some electrical tape on top.
0C2C22E8-9097-4A2E-9E81-F2586730A2E7.jpg~original
In the end, all this was to turn this monstrosity...
D87B2FF8-5725-4F59-8900-F9F834FE4E37.jpg~original
Into this cleaner look.
C19184F0-4DEA-4D03-9A2D-5608DE228BA7.jpg~original
If I could do it all over again, and I may, I'd install the port upside down. That way I don't notice the blue light as much and the rubber plug is tough to pull out from the top.
Amazon.com: FAST Shipping* ADD CIRCUIT BLADE STYLE APS ATT LOW PROFILE MINI FUSETAP FUSE TAP + FUSE SET 5, 7.5, 10, 15, 20 AMPS: Automotive
http://www.amazon.com/Charge-Adaptor-Socket-Dashboard-TOYOTA/dp/B014WCH2YS?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00
Nice find on that USB socket!
