Adding push button start
While "anything" is possible, this would be pretty expensive.
You must consider:
1. The current steering column lock on your truck is mechanical. That means, to unlock your steering wheel, you need the key. (In my limited, the steering wheel lock is servo-driven. That's to say, when I press my button [with my fob in the car] the servo activates and "unbolts" the steering wheel. Like wise, when I turn the car off it re-engages to lock the steering column)
2. The "push button" start systems consist of several security features, my smartkey for example is programmed into my truck's ecu so that when my smart key transmits to the vehicle the vehicle's antitheft system is disengaged. Your SR5 has the chip in the key itself, so you'd have to somehow swap all that stuff out (Again, not very cheap here)
3. While you could add a "push button" start, per se, you'd still have to put your key in the ignition, turn it to on, and then press the button (in lieu of twisting the key to start)
This feature is so incorporated into the vehicle itself that it's not just a matter of putting in the button etc. There's quite a lot to the smart key system (sensors and such). There really isn't a very simple way to add this functionality - it's just cost prohibitive.
You must consider:
Keeping Antman's post in mind: http://www.arbouw.com/Honda/S2000StartButton.asp
I added an S2000 start button to my 2002 Honda CRV. IF you want you can leave the steering wheel lock unlocked and instead add a master electricity switch to enable the vehicle to be started; that does make it also easier for the vehicle to be stolen.
Okki
waterman2258
