Aftermarket Stereo
Love the install, and the Pioneer AVH-X2700BS. Install was in family member's 2010, and was replacing the Kenwood DDX392 I installed 2 months ago (bluetooth quality was terrible on Kenwood). Very pleased with fit, and sound quality, even with stock speakers!
With the AVH-X2700, are you able to use the push to talk button on the steering wheel to initiate a phone call? What steering wheel control interface are you using? I'm ready to buy this same unit but I don't want to give up push to talk phone call.
Highly unlikely. I have the 5700 and can't use that feature. You need a unit that is voice capable so are probably looking at a 7 or 8000 series.
Pm'd you back
You can replace the piece of junk pioneer radio that came in the 4runner with a Astrium GEE-17155. You can replace it yourself. Go on ebay and search for the radio it comes out of Canada. It cost around 700.00 dollars. I replaced my radio with this one, looks factory, works great. Also search on this site for instructions on how to install.
Thanks for this. My touchscreen went out, and really want something as close to OEM looking as possible, without spending 2k from Toyota.
One thing to point out for others, is I think the model may be 1715, not 17155. Took me a bit to figure that out.
http://astrium-electronics.com/toyota-4runner-gee-1715.html
http://www.toyota-4runner.org/5th-gen-t4rs/166652-oem-looking-5th-gen-nav-info-thread.html
Touchscreen going out is really frustrating. Im going to try to get Toyota to replace it at a discount once more, but the Astrium is probably the way Ill go. I do with their interface was a little better though.
In-dash OE Navigation :: Toyota 4Runner GEE-1715 -
If you feel like you want to go with stock - I've got a 5th gen touchscreen/nav/etc. (out of a 2012 trail) that is just sitting around.
So I just had a kenwood DDX9902S (Carplay) put into my 2010 4runner. It looks awesome and the metra kit matches the rest of the dash. With the steering wheel adapter and rear view camera adapter (will be installed next week), everything works with the head unit. The steering wheel volume/channel/mode buttons all work and using the bluetooth phone buttons activate siri and controls the phone answer/hangup buttons as well. Now I just need to replace my stock speakers and add a small subwoofer in there and it should be awesome. Anyone recommend any good speakers?
Hello folks.
I have a 2012 trail with the non jbl with nav stereo unit. I need help finding which wires is the factory back up camera and antenna wire. I looked all over and found kingpins thread but his photos aren't working. Here is a picture I took of the back of the unit. I'm installing an aftermarket head unit...
Also which one is the reverse sensing wire?
Hello folks.
Hi ahproh,
In the photo below, The GPS antenna is marked by the RED arrow. The Back-up camera uses a Shielded cable and is likely one of the two cables I have highlighted with BLUE arrows; the harness is compiled of four wires: RED, BLK, WHT, and Shield (color unknown). You'll need to pull the two connectors from their receiving portals to identify the wire colors beneath the shield to reveal it's usage.
The REV lights trigger wire is RED and lands at the number 2 terminal on the HU's rear panel: "See the blue circle and arrows upper left-hand corner on the diagram below". It's almost impossible to ID these wires using a photograph so you'll have to figure it out based on the diagram and the actual navi-unit, Best!
Info for using SFA12F cable on JBL/NAV 4runner with aftermarket head unit
I wanted to add this for others that want to use the factory Sat. antenna with an aftermarket head unit. I couldn't find this anywhere when i searched.
SFA12F is the cable used . see pic
Female end of SFA12F attaches to the 300v1 or whatever you choose to use.
End with plastic attaches to the cable (one you disconnect from the box under pass. seat) that runs to the antenna in the shark fin.
For those who want to use the OEM camera JBL/NAV. 2010-2013
I couldn't find any info on doing this mod with a factory JBL/NAV head unit 2010-2013?
I'm not 100% if this will work on the newer years. but if your plug matches up you are good to go.
I didn't convert to 6v and the camera works great. But if you want to I found this on Amazon.
Amazon.com: SMAKN Dc/dc Converter 12v Step Down to 6V/3A Power Supply Module: Electronics
This is seriously an easy thing if you know the wiring.
I used posi-tap connectors.
Pin 21 blue camera ground
Pin 22 white video
Pin 23 Black video shield
Pin 24 Red camera power
First pic is the camera feed to RCA.
Second pic I attached the power and ground.
Thank you. I ended up using this on my install and it works great!
What to do with factory Nav unit
Hey guys,
I am new to the forum as well as a new T4R owner (admit I was a Wrangler Unlimited man) and I am going to replace the stereo that came in my 15 SR5 with navigation. I am wondering if I will be able to sell the factory unit to someone who wants to add factory navigation to theirs?
Thanks and I am loving this vehicle
Hey guys,
Is yours JBL or non-JBL? How much do these factory units usually go for?
Pin 22 white video
Did you connect the Red camera power wire to a constant 12V source or a switched source? Any negative effects from running it 12V for a few months now?
Information display features being lost
Can some answer if replacing entune with aftermarket one. Do you loss any functions on the dash center information display. I have a Nex4000 in my current vehicle and when I get my 4 runner I want to use it in the 4 runner. Just trying to understand everything I need.
freddygino
