Air on Board Switches...why no blue for 2016 model?
For another source for blue switches for the 2014+:
I just received a blue push button almost identical to the AOB switch from Cruiserheads. The switch is made by "CH4x4". You can get these in different combinations from Cruiserheads or from Amazon.
They are basically the same, except that the AOB switches are less rounded in the corners.
In the pictures, the center camera switch is the Cruiserheads switch. The outer AOB.
Just be sure to get the switches that the face is ~32.54 x 22mm.
They both feel about equally cheaply made. :lmao:
:cheers:
In your opinion, between the two, which one has shape and texture/color most close to the stock switches?
The OEM switches aren't as rounded as the CH4x4 corners. The AOB switches are a bit more sharp in the corners. :wacko:
If I had to choose, I would pick the AOB, but neither feel as nice as the stock switch. There seems to be a mix match of wiring colors as well, even between my AOB switches..
AOB didn't have stock. I know a few folks are looking for blue camera switches sooner than later due to the recent camera dongle. I plan on adding the camera switch on the right side of the steering column, so the shape wasn't a factor.
:cheers:
TerryNap61
