Air outlet noise
4Run14
'14 SR5 Prm
20 degrees. This morning as my vehicle was warming up I changed the air outlet from blowing heat to the main area to blowing down to the floor. When I did this I heard some buzzing which lasted 4-5 seconds and it was coming from behind the dash. So I tested it out. I kept switching it from one to another, back and forth...same noise was heard.
After 5-10 minutes of driving the noise finally went away. Is this normal?
sounds like the servo has an issue.. usually this only tends to happen on high mileage cars. have the dealer check it out.
"After 5-10 minutes of driving the noise finally went away. Is this normal?..."
Hi 4Run14,
There may be a pneumatic servo (w/linkage, blend doors...etc) in the dash that is noisy due to lack of use and radical temp changes. Continue to exercise the climate control system and allow the control modules to 'break-in'; the sound should become less noticeable across time. rgds!
rigtec, cheers
So far I haven't heard it come back and it did get really cold here recently.
when they do start to go bad, it starts in the real cold weather then a yr or so down the road it'll do it all the time.. mine had went out in my lexus.. sounded like mice scratchin' back there.. if it goes away and never comes back, it was probably a leaf
You're wasting OPs time telling the dealer to check it. If he can't make it happen for them they won't do anything.
It just happened again this morning. Seems as if if it sits overnight in the cold garage it keeps happening.
4Run14, maybe you could use you're cell phone and try catching the sound on video. Show it to the service tech when you go to the dealer. Posting it on here may aid the forum in helping as well.
I can definitely try that in the morning. I'm not sure how well the sound will come in though and where exactly I should hold the phone.
minearcj33
