American Racing AR23 for 2002 SR5 4WD Questions
cannonball
Hello:
I was hoping someone with experience may perhaps help with answers to the following questions regarding the fitment of American Racing AR23 Wheels to my 2002 4Runner SR5 4WD. My questions are as follows:
1) I am considering the 16X8 AR23 mated to 265/70/R16 tires. This is the tire size the vehicle had when I purchased it used in 2012 and what I have continued to use. Many of the distrbutors for the rims indicate that a lift kit "may" be required. When I inquired about whe a lift is needed (non-stock tire size, etc), I cannot seem to get a solid anwser, just that is a required by the mfg to make that statement. Can someone please tell me if my tire size combined with the stated rim and stock ride height will cause any clearance issues? (I should also state that I do not "off road" with my 4Runner. It is daily transportation with a considerable amount of long distance highway use.)
2) I understand that the AR23 is a "lug centric" wheel while the stock rims are "hub centric". Are there any hub spacer rings recommended for the AR23s that would take up any hub gap and eliminate the possibility of undo wear or vibration at highway speeds?
Thank you in advance for any insight you may be able to provide in order for me to make a qualified decision.
Respectfully,
Tom
Hey Tom,
To answer your first question- 265/70R16 will clear just fine with a 16x8 wheel with a 4.5" backspace(AR23 specs).
Second, you need something like these-
https://www.amazon.com/Gorilla-Automotive-108-106-1-Centric-106-1mm/dp/B0032HQJ7G
Those don't have great reviews, so I would do more searching on Amazon and eBay for "106 108 hub rings" for a more quality product.
Definitely use centering rings if you have a different size hub bore on the wheel.
Have fun,
Tyler
Hi Tyler:
Thank you very much for your response!
It was very helpful.
(And please excuse my "typos" in the original post as I'm trying to get used to a new keyboard on a different computer...LOL!)
Tom
I had those wheels at one point with 265 75 16 and never had any issues. I never used hub rings or anything and no vibes.
I'm not saying it's not a bad idea to use them just throwing my experience out there
Shouldn't need hub rings, they're quality wheels and leave good engagement on the studs, I had them in 15x10.
