Another Full-Length Roof Rack Option -PrinSu
jareda80 Nice looking truck !
It is hard to tell from the pictures posted , does the fairing rest on the paint or is there clearance?
Thanks! No it doesn't rub, there is probably 1/4" gap. It's also adjustable. The nice thing is it's aluminum so it's not going to vibrate or move on the freeway.
Going with the same setup as you. Did the 3/4 rack come with a total of 9 rails?
The 3/4 comes with 6 rails. I will probably buy a few extra once I figure out how I'm going to set it up for camp season.
Also, for some reason my sat antenna was in the way of the rear crossbar so we moved it forward and Zach has a single mount rear bar that will go on the very back. This is the first time he's ran into this so not sure if they changed the antenna size for 2016.
When you get a chance, can you snap a top shot of the roof rack from above? Thanks!
Jared,
Would you mind giving us the dimensions? It looks like it will be hard to lay something flat that is longer than the rack, given the way it kicks up at the front. Thanks.
meh, I wanted to like this rack but it just seems lacking. Cool design but just doesnt strike me as capable as the K9 or Frontrunner....
Doing research on racks for a new 4Runner. Like baja and gobi but leaning towards baja for costs.
Just noticed they have a universal rack that mounts to the roof rack bars. Anyone use this? Half the cost of the model specific and only slightly smaller.
I think it all really just comes down to intended use. I'm trying to keep this build light and versatile as I will be driving this rig as much to Colorado, Moab, etc. on the freeway for biking as I will going on Overland trips. I agree it isn't as wide or big as a K9 or Frontrunner and wouldn't hold the same amount of gear but it's definitely lighter and probably fits my needs fine. The only things I will be throwing up top is a smaller RTT and maybe some Maxtrax. Everything else will be inside or on the aluminum back bumper once I order one. And if I need more space Zach said I can swap out the side rails for full length which would give me more that enough space. I like the look of it and like supporting local guys so it's a good fit for me.
Jared,
As soon as I can find my tape measure I will measure it and let you know.
Do you mean capable as in carrying capacity in Lbs?
I'm also looking hard at the K9, Prinsu, and Front Runner racks, and leaning hard towards the K9. What the Prinsu has going for it, in my eyes, is:
Availability. Made in 'Merica, which means you're not waiting on a cargo container from South Africa to arrive in order to get your rack. Not sure exactly how long it takes to receive the Prinsu rack though.
Modularity. You can add more cross bars to increase capacity, but you also control the total weight of the rack when you only add cross bars as needed. Also, I like the idea of using easy to find 80/20 parts to mount things to the rack instead of proprietary mounts.
Price. Under $1K.
Interesting rack... like the fact it's Aluminum and the slots are removable.
Any idea on the carrying capacity? Would be nice to use this for a RTT...
[MENTION=129245]ArchieBunker[/MENTION], could you take a closer picture of the feet from the inside and how it mounts up with the rail and roof? I am wondering if a foot couldn't be fabbed up instead of the plusnut solution...
pjo
Who here owns a Prinsu rack?
Jared,
Ok here are the dimensions. All length dimensions were taken from the rear most point of the side plate.
47.5" wide (outside edge to outside edge)
64.75" long (rear most point of side plate to front bottom edge of wind deflector)
60.75" from rear most point of side plate to top edge of the wind deflectors. So your interior usable area would be roughly 47.25" x 60.75".
53" to rear of front most cross bar (still has mounts for another crossbar forward of this crossbar but it would be in the kick up area)
1.25" total rise at top of kick up versus the main flat area of the rack.
So it's definitely big enough for your average RTT and could probably fit a couple narrow things like Maxtrax forward of the tent if you mounted the tent flush with the back.
brendaglores
