Another thread about ball joints
Hey folks, so I know the consensus is to replace them, and I'm going to get this done this Spring once she comes out from her winter slumber.
Perusing several threads here, a few things seem to gel.
Go OEM, not aftermarket.
Replace the bolts, don't reuse the old ones, (I'm unclear on this here) 4 on the lower, another 4 on the upper, or 4 total?
Questions.
- Is there any value in a "high performance" upper that's greaseable, such as this one I found? Or still go OEM?
More Information for MEVOTECH TXMS86563
- Do the bolts come with each kit, or are they a separate order item, and some folks just don't bother to use them?
Putting on some new wheels and 32's, so getting a bit of lift work done too, unsure if that'll be just spacers, or whole new parts, so it seemed like a good time to get the joints done.
1996, V6 SR5, 139K, 4WD, no real off road use/abuse, for what that may matter.
Thanks all!
Replace the bolts, don't reuse the old ones, (I'm unclear on this here) 4 on the lower, another 4 on the upper, or 4 total? 4 bolts per Ball Joint - OEM Bolts are just fine for Daily Use. Get the right ones for your year - You also need new Castle Nuts and Cotter pin X 2
Questions.
- Is there any value in a "high performance" upper that's greaseable, such as this one I found? Or still go OEM? - OEM only for Upper Ball Joints. My buddy has a set for sale for 60 bucks per side if you are interested
- Do the bolts come with each kit, or are they a separate order item, and some folks just don't bother to use them? There is a recall kit Part # 04005-02235 that contains both ball joints. You will need to purchase the Castle Nuts and Cotter Pins separately.
Thanks!
I found the castle nut/pin kit, one per ordered unit. Listing says 4 are needed for the vehicle.
Castle Nut - Toyota Ball Joint Castle Nut and Cotter Pin KIT-1099
But 4 bolts per lower, and 4 per upper, adds up to 8, not 4. So only some of the bolts get those specialty retainer nuts, per assembly?
I haven't done this job, nor am I doing it, so I just don't want to come up short, or buy extras that I don't need.
As for your buddies uppers? Sure, got a link or an email for them?
AndiGarage
