ANTMAN'S Thread
Congrats on the new shoes. Having the letters on the inside would gain you 5 HP and the kids won't laugh at you. :clap2:
I guess I'm old school because I'm rockin' those white letters, baby.
I feel like The Fall Guy...Google it youngsters.
Enter the 285 BFG KO2's- E load. Tire Rack has an incredible deal on these right now- especially if you pick them up at one of their warehouses (no shipping cost). Go check it out, you won't believe the price! Best I could find by about $300!!!
These ride really nice- very quiet and smooth. I did some fender-liner trimming as expected and I think I got rid of the rub...
Don't they look great?! My buddy Brad at work even mounted the tires so the white lettering is centered over the valve stem on all the wheels.:thumb:
Hopefully these will get me past 200,000!
Do you still have your wheel spacers on or did you get rid of them with the new wheels?
I need to unsub this f&$@Ing thread...
I installed my HAM like your scanguage Jeff
What a PIA
8A3FBB36-B773-405B-9040-FDA4D4564C5B_zpsisdyo4hi.jpg~original
It's done! The front bumper has been trimmed and installed- I think it looks great! Pictures don't do it justice. Way more clearance and it looks much more aggressive. First the pics- then the issues I had to overcome...
All trimming was done with a Dremel and a reinforced fiber cut-off wheel- slices through like butter. Once I cut the bumper and fitted it there was some more trimming to do. The aluminum support bumper had to be trimmed a tiny bit, maybe 1/2" on the end- I left the metal brackets on there (important-read on).The fender liners needed trimming as well. Trimming the liners was easy, but I made sure to leave a section on there that could be attached to the metal brackets. The liners need support or they will flap around.
Now the part that I knew would be a challenge- but I came up with an easy solution. Once you cut the rounded part off the bumper you lose a lot of structural integrity, and looking up underneath the area is unfinished and exposed. I knew this going in and planned on fabbing some filler plates for the area. But... the pieces that were cut off can be trimmed and re-used to cover the hole and support the bumper. They attach to the metal brackets as well.
I realize that right now this looks like ass, but the reality is you can't even see this unless you crawl under there. These rounded pieces took the brunt of the trail rash on the front. I will be pulling them off again, sanding and painting with bedliner for a finished look. It'll look acceptable after that. Here's a pic of the filler piece for now.
All that really matters is that Grace approves, lol. :drama:
I'm ok with it, but Grace clearly is not impressed... :shrug:
#cbifullsteelbumper
Grace's actual words- "We did it Dad. Now it looks like a bigger truck like I always wanted it to." (She was in charge of the flashlight for this one, lol)
She makes me so damn proud!
Nice job
I had been thinking of doing the same trim to mine as all of my cuts and scrapes are on the areas that you trimmed off. However, I don't have much damage on the corners - So I've been thinking of taking out just the center portion and not the corners that way keeping a bit more structural integrity.
I like the look though.
Nice [MENTION=65614]Antman[/MENTION]. I always contemplated doing something similar to mine when I had the stock cover. I tried putting off the aftermarket front bumper for so long and kept thinking how I would cut the plastic cover instead. Nice job.
[MENTION=65614]Antman[/MENTION] Your thread is amazing! As a new 2011 SR5 owner from Canada it's really helpful!
Any tips for how you taped off the front section of your bumper for the rocker spray? I'm hoping to be able to leave mine on the vehicle, but can't quite figure out how to tape. Did you pull once dry?
- mine has many rock chips and I think this would be a good way to go!
I sanded the shine off, wiped it down with acetone and a tack cloth and sprayed it. Yes, you pull the tape off once dry.
Thanks for the compliments!
You fix that door yet?
Nope. U fix that qtr panel yet?
Man! Where to begin?
You do some great work sir! I've been reading your posts for a while now and you've given me plenty of ideas and things to put on my build list. And cost me some money too haha but not much ;)
Love your rig, thanks for all the posts and keep up the great work! :cheers:
Lol- I fart in your general direction!
erinobr2000
