Thanks for pointing those out, unfortunately not enough...
Heavy Duty Springs Specs:
Free Length - 19.25"
Bottom Coil Rate - 300lbs
Top Coil Rate - 104lbs
Lift Height - 3"
Well... lemme do the math quick... Rear bumper without swing out was 110#, swing out, full size spare, recovery gear and ammo can are around 180#, Fuel tank is light (maybe 10 lbs with sending unit and fittings, 13 gallons of fuel (not all the time) @ 6.08 lbs / gal = 79#. There is 379# in just the rear bumper - I have the Gobi stealth, a full width "stealth" tool box up on top with a full set of tools, a high lift and shovel.... Not sure how much of that weight is distributed over the rear.... And then there is the rock armor - bud build beefy sliders and full front to rear Shrock skids add even more weigh. My rough guess.... I have probably close to, if not over 500# additional over the rear axel, depending on whether I have the fuel tank full or not.
Honestly, my gas mileage took the biggest hit when I sized up the tires to the 285's and added the Gobi rack. Even with everything I have on there and the new front bumper, I still manage 13 around town (mostly stop and go) and easily get 17-17.5 on the freeway. Just made a trip last weekend down to the desert with 2 other guys and a TON of search and rescue gear in the back of the truck and still managed over 15mpg average from my house, down to the desert 80 miles away, 5 miles up a dirt road, and home. The key is to drive slower than normal, any faster than 65 and you can watch the gas gauge drop...
