Auto Dimming Mirror Install w/pictures
I park the 4runner in the driveway.. afraid someone might break the window and open the garage. Just paranoid when I am away on short out of state trips
I just padlock the garage door/rail lock when we're out on trips. Block any access to any hooligan who might want to get in.
Nice write-up! I ordered my gentex auto dim w/amber hidden compass this morning. I didn't realize how nice it is to have auto dim until I didn't have one anymore! My 2013 Tacoma had one and I sort of assumed that a 2016 TE would have one too... and it will in a few days.
[MENTION=80933]4x4runner2002[/MENTION] This is the install that I was referring to with tapping into the moon roof.
If you want a cheap mirror and look in your local junkyard for one from a Camry, apparently the later 2000s are the same. I can get them for $3 if/when they have one.
To anyone needing help finding a Gentex mirror, I would advise you to just visit your local U Pull lot for the best prices. I just pulled 3 more to wire up in the family fleet of vehicles (cheaper than buying a universal clicker for each vehicle!). The most common will be Auto Dimming + Homelink (all that I really need). You can find them with the compass and or temperature add-on if you're lucky.
You want post 2000's vehicles. The newer, the better.
Next, Gentex mirrors are used in a lot of vehicles as upper or premium options. Base model something? Pass. Look at a vehicle/trim that you know is decked out. GM trims have mirrors with their proprietary OnStar button. I pass on these also.
You'll need a small star bit to loosen the base of the mirror (keep the screw!), the pig tail (cut off as much as you can, fish it out of the headliner), the plastic piece that'll cover the exposed wire harness (careful, its fragile), and the mirror itself.
**If you're pulling a mirror with the TEMP function, you'll need the temperature dongle. It's usually mounted in front of the radiator/crash beam. I have yet to find one in my yard as the crash beam is ripped out when the wreckers pull the engine and transmission.**
So far, I've pulled Gentex mirrors off 2x Prius, Nissan Maxima, and an Infinity M35. Paid $10.00 a piece. Once you know which vehicles to hunt for / which to avoid, you can find them pretty easily.
Happy hunting and modding!
I have a 2016 SR5 with out sunroof, will I be able to get a ACC/Ignition power from the overhead console without going all the way to the A-pillar and under the dash ?
Did anyone have an answer to this? I have the exact same thing. Looking to do the install tomorrow.:nicethread:
Tried going to the U-Pull it. Found a couple that could work, but they were blue/green. They wanted $20 a piece for them. Pretty steep for something that may not even work.
Anyway, found one on ebay. Amber, auto-dimming with compass, $50 shipped.
Wondering if you HAVE TO disconnect the negative on the battery to do the install?
I rebelled. I didn't. Test wire harness for power (if you're unsure which wires). Pull key from ignition, pull harness plug and trim back the electrical tape to give you more slack, tap, tap, tap, reconnect harness plug and done.
sorry to hijack this thread, but i think this issue is somehow related:
anyone know what is the color of the wire in the wire harness located close to the map light? my mic keeps on disconnecting, i might have loosen the pins when I tried to look for the +/- source...
I tried to push all the pin connector several times already but after a while, the mic disconnects again... I'm planning to hard wire it instead.
I put the mirror in my 04 but after I got my 07 I couldn't find one reasonable enough so i picked up one from an 01 Tahoe for three bucks at the junkyard to use til I find a Toyota cheap.
Edit, I've since swapped one out for a $5 one I pulled out of a Camry. Works mint.
Sorry if I'm missing something obvious - but is there a link to the place I can buy this mirror? (if that is allowed?)
Garrett
You can also grab one from a junk yard. The GM's and Jeeps I know are the straight forward Gentex mirrors that you can easily wire up. I have the one with a compass that I grabbed out of a suburban if I can recall.
Sent from my Pixel 2 using Tapatalk
how about mirrors with temperature showing on the mirror. How to install it to work. And is it going to show in Celsius or Fahrenheit.
You need to grab the affiliated temp sensor and wire it in. Usually see them on the radiator support beam.
Configure your mirror to run *C or *F.
Thanks for the info.I was wondering is there any OEM mirror wich shows temperature and can be showing Celsius.Im asking because my car is showing Fahrenheit and want Celsius.
Is there really a benifit to these mirrors? the reason I ask is I hated the auto dimming mirror in my wifes Deville, it never worked very well. Do these mirrors also have the camera and built in DVR to record while you drive?
I think so.
I have one in my Acura TL and it works great, performance and diming levels are spot on … it’s something I notice and miss when jumping into my 4Runner or Silverado.
Integrated DVR seems like a really good idea too.
2001ATL
