Everything go okay with programming the new ECU?
Yes, it worked like a charm. The FSM instructions were the same as what you posted.
I have a '15 with the automatic running boards and they tend to get stuck/delay more often than I'd like. I sometimes just open the door and close just to trigger them after I'm already inside. It's a neat feature, but can get annoying. Been debating on getting rid of them.
If you turn on the car while they are deploying they get stuck. Outside of that issue there is a TSB for the replacement of the ECU that controls the boards. Removing them is very easy also. I kept mine because it was easier for my little kids to get in and out. I was debating sliders but it would still be harder for the kids to get in.
If you do want to remove them I've attached the instructions.
It looks like I will need to replace the ECU to resolve my issue ( https://www.toyota-4runner.org/3331155-post47.html) and I'm looking for any info about location of the ECU, auto boards/step disassembly...?
BTW, where did you buy the ECU from ( what website)?
I can't open/download the EXTERIOR PANELS TRIM AUTOMATIC RUNNING BOARD REMOVAL 2014 MY 4Runner [082013 - ].pdf, tried on different devices... Would it be possible to check if it is working for you?
Sorry just saw this.
I got the parts from McGeorge Toyota:
Computer Assembly Side - Toyota (89720-35011) | Toyota Parts
I uploaded Jpeg images, does that help?
I know this my be to late but I used an Amped research controller for my OEM running board install, I bought it and a wiring harness for less than $200. The factory controller has a lot of input signals, any one of which can jam up the steps. With the AMP controller if the door is open the step goes down, simplicity.
If for some reason your running board motor goes bad check out Amazon. The 4 runner uses the same motor as the Ford trucks and SUV, just different harness plug.
Perfect! Thanks!
BTW, where did you get the images? Happen to know of a service manual for 5th GEN T4R, in PDF format ( or other digital format)?
