AVN5500 updated DVD in AVN5435
Actually the disc doesn't work very well. I tried loading it and it just halted. I had to place my original v1.2 back in to get it going again. I think the two possibilities are:
1.) Perhaps the AVN5500 disc was not meant for the AVN5435?
2.) Perhaps it was just a bad burn.
Yeah, it might just be a bad burn because even my computer took awhile to load it compared to the original 1.2 Eclipse disc. I noticed it was burned on a DVD+R DL disc. Maybe it would work better on a DVD-R DL disc? I might get some blanks and re-burn it just to see.
Re: v1.3 (AVN5500) DVD
mit_peid said:
I just got my disc from nyc4runnin today in the mail as well. I popped it in and although it took a while, it did read it. I looked it up and it said v1.3 DVD map disc. So thats good. I think I also need to disconnect the power, or at least take out the fuse reset the stereo. Anyone know which fuse?
v1.2 was what came with AVN5435 originally. v1.3 comes with AVN5500. and v1.4 is what is being sold separately.
Also, another question, does anyone know if v1.4 software will upgrade the Ipod functionality of AVN5435. If it does, I'm in for sure!
there's 2 20amp fuses for the radio is under hood driver side, it easy to find it label as radio no.1 and radio no.2 just look at flipside of the fuse box cover. yes i did try remove the fuse and put it back in to reset the hu but the new map wouldn't load at all.
Bala de Plata said:
How do you access the secret menu?
Hit the "Menu" hard button, then go to the Volume menu, then tap the upper left corner of the screen with your finger, then the lower left, then upper left...repeat about 3 times until the hidden menu appears.
secret menu
so with this secret menu procedure were you able to load v1.3 map disc with no problem and everything else(poi and address search) also work the way it should be.
Re: secret menu
I wasn't able to. When I hit the "Loading" button on the hidden menu, it said "check map disc". Using the original 1.2 disc worked fine though and it seemed to reload the original firmware and set everything back to the system defaults.
mit_peid, were you able to get it to work using that menu?
Re: Re: secret menu
Once you update to a new disc, I don't know if it revert back to the old one.
But there are a few version out. Like you mentioned above: 1.2 was the 5435, 1.3 is the 5500. There is a version 2.0 which is made for the 6600. the vesion 1.4 is sold seperately with firmware update and some little other stuff.
I read up at a Corvette Forum that once a firmware is updated, they're not sure if it can revert itself.
Yes. I was able to get it working fine again with v1.2.
I'm not sure if v1.3 ever had any updated firmware. Once I took out the burnt v1.3 disc and reloaded v1.2 everything worked fine again.
I had to set all my settings again (turn off the annoying beap) but I don't think it has any issues going from the different discs.
i am currently using the burnt 1.3 DVD+R DL disc in my 5500 with no problems. maybe v1.3 just isnt compatible with the 5435 ? also have you people noticed very poor gps reception when it rains\snow's or is it just me ? DAMN CLOUDS
v1.4
I'm currently using a burnt v1.4 disc and it works very well. The MP3 functionality seems to work a little better and filenames now come in upper AND lower case.
Street mapping (75 ft maps) with buildings in major metropolis type areas (ie downtown LA) seems to work good as well.
Does anybody know how to get the wallpaper function to work?
Re: v1.4
I just got a burnt disc from seconds2none and it's working great also. Here's a link from another forum with instructions on how to change the load up graphic:
http://www.tundrasolutions.com/forums/477233-post25/
Too bad there's no way to change the wallpaper , but this is better than nothing I guess.
Re: eclipse mdv-06d
moxie6178 said:
Does anyone know if the update disc makes the AVN-2454 Sirius Ready?
Hi guys,
I signed up on this forum to respond to this thread. I can confirm that the update does indeed enable the AVN2454 to use the Sirius tuner.
Sirius update
I got the 1.4 disc, installed it and nothing. I checked the hook up on the sirius and its correct. There is no Icon for sirius anywhere. If anyone knows a thing please let me know
Re: Sirius update
Make sure you have the lan cable plugged into the "out" port on the Sirius tuner. Also, when you inserted the 1.4 disc did it give you the message saying system loading?
Sirius Ready
I can't remember if it said system loading. I switched the cable from in to out and out to in and there was no change. I have the AVN 2454 and it is the only one that is not sirius ready. Do you have the same model?
Yes I have the AVN2454 as well. I would check the yellow battery wire and ground on the Sirius module. It sounds like it is not powering on. The lan cable definately belongs on the out port. You could try unplugging your hu and then reinstalling the 1.4 DVD and see if it loads the update this time.
Also, the right-angle end of the lan cable should be plugged into the sirius module and the straight end into the hu. I'm not sure if it matters though.
