AVS bugflector - at my front door!
mtbnole
and it's scratched quite a bit... called autoanything and the guy told me there is a very thin film on it which should be removed. i'm having trouble finding this "film". anyone with one of these have this issue? I want to put it on, but want to make sure this is legit...
thanks!
rub your nail across it...if you can scratch it, then there is a film...if you can't then there is no film and the scratch is in the plastic.
no film, and the scratches aren't as bad as I initially thought. I did call them back and they said I need to call customer service monday morning. He also said they will probably just send me another one. we'll see...
I can't believe how easily these scratch. I put the Toyota deflector on my TE in the fall, the vehicle went into storage for the winter and I had a car cover over it. When I removed the cover a couple of weeks ago I noticed scratches that were ever so fine but still distinct. They had to have happened while putting the cover on and taking it off. This was a very light and breathable cover. I know that they make a product for removing fine scratches in plastic motorcycle windshields that according to my friends works very well so you might want to try that if you decide to keep it or experience scratching down the road with it's replacement.
is it gray or black? if it's simi gray then the film is still on. i had the same reaction when i got it. you can try using packing tape and slap it on the edge and pull up slowly from there.
+1.
I pulled it out of the package and said, "whoa".
Then I figured out that it was a film.
