Best Handheld CB?
Kraeken
I am thinking about getting a handheld CB for long road trips and going out on the trails. I do not want to get a hardwired CB. What is the best option, a good compromise between price and quality? Maybe also something that can be hooked up to an external antenna for better range.
Just realized where I posted this- mods move it if you think it should be in another section...
I am like you. I don't really want it in my truck all the time. I bought the Cobra 75 WX ST that is so popular as it only has one cable that connects to it. The transmitter box and power junction are about the size of a half a box of kitchen matches. The connector which includes everything (the single cable I mentioned) I leave tucked up under the console by the carpet and I fish it out when I need to use it, plug her in, screw on my antenna and I am set to go. When done I unscrew it tuck the connector back under the dash and take off the antenna and I am back to normal after storing the antenna and the hand unit in the back or with my gear. Great little radio, highly recommend it.
Agreed. My solution will provide a less bulky condition than a handheld, however - and still provides the easy ability to remove it.
Interested too.... Subscribed
a bit off topic and just my .02, but get your ham license. with just the first level (technician) you can use your handheld to communicate directly (couple mile range) or by using repeaters on the 2 meter and 70 cm band (144mhz and 440mhz ranges), be able to talk (depending on propagation) up to 50 miles or more. those of you 4wheelin' out in TX and CA, have a bleep-ton of repeaters and in remote areas have near unlimited range.
you can study online and w/i a week or so take the test. although i'm only scratching the surface here and the hobby gets much more involved, it really is that easy.
also, the gear is top notch by the best names in electronics. nothing against Cobra, but it's not even in the same universe as ICOM, Yaesu and Kenwood. for around $300-$400, you can get a handheld that's submersible, built to military standards, able to xmit on both bands i mentioned, scan public saftey and marine freqs, listen to shortwave and broadcast radio, get WX alerts and updates, use APRS to send messages and map and locate beacons, etc. i know it's not cheap but it's quality and you can't beat the bang for the buck.
didn't set out to hijack your thread, but after all the advice i've gotten from members here, just thought i'd give a little back. take care.
I know ICOM and Yaesu make good stuff, I run across them in my line of work. But Kenwood? Really? Their stereo equipment is garbage.
Thank everyone for the info so far. I want a handheld for two reasons-
1- I don't want anything in my car that will seem tempting to the skells in the hood where I work. On 9/11 last year, I was standing at attention at a memorial and they were around the corner stealing the end caps and kayak pads off my roof. WTF?
2- I want something that I can use to communicate when I'm away from the truck as well. The same way I would use an FRS radio. I have a handheld marine radio for sea kayaking, I love the portability.
I would, of course, get an external antenna for the truck.
Its 50-60 bucks now. As long as none of them are really duds, I'll pick up a handheld in that price range sometime soon.
Thanks!
Halligan has this pegged. I have the ICOM 2820 in my truck and a Yaesu VX7R Handy Talkie as a backup. Getting your HAM Tech License is the way to go!! KE5ZCX
Clocktower07
