best sparkplug / wire set?
all this coming from the guy who found me a second gen bumper for my '01 :sobbing::bravo:
hahahhah totally joking, I'll post on that thread in a bit...
well I could get you spot-on accurate MPG ratings to the tenth of a mile using my gas cubby app, but I'd never put that sh!t in my truck:biggrin2:
LOL in my defense, I posted a pic up on facebook of the bumper and U assumed it was for a 3rd Gen! Of course I dont think it occurred to anyone to ask what model it was for! :ybrick: and I think that the guys at Jims thought it was for a 3rd gen too...
haha i'm joking man, it worked and that all that matters
still not putting that bosch garbage in my truck.:repuke:
Picked up oem denso plugs and wires. Getting ready to go put em on in a couple mins. Hopefully it will bring the mpg up. We can only pray lol.
From my research, the driver's side calls for the Denso K16TR11 and the passenger side calls for the NGK BKR5EKB-11. Not that doing it makes much of a difference, but I did go with the mixed plug set when I did my recent tune up. I also went with the NGK wire set. I pulled out a full set of very worn Denso plugs, and the OE spark plug wires. Right now I'm seeing a jump from about 13mpg (mostly very short trip city) to about 17mpg.
IIRC, even though the OE wires have a Denso part number, they're made by Sumitomo.
wow thats a HUGE upgrade for MPG!
i only hope mines does that, i ordered it through amazon chose the free shipping cause im cheap ass, now i have to wait to "estimated delivery march 4"
HAHAH
oh well.
but i order 6 of the same NGK can someone tell me, did i order wrong? i hope not.. i didnt know you had to choose 2 differnet!
HAHAH
oh well.
You don't have to run the 2 different brand plugs, just one or the other. Make sure you have dual electrode plugs.
1 pack of 3 wires. The other 3 cylinders don't take wires, they sit directly under the coil packs and have boots that don't need changing except maybe every 10 years or so it seems.
Have a 2001 4Runner with 172,000 miles.
Getting ready to do plugs and wires. Would you recommend doing the boots for the other 3 cylinders? If so, are they an easy replacement?
Thanks!
The boots wouldn't hurt, but most people don't seem to change them until they have a problem. They are pretty cheap though so with 172K, I would probably do it if I were you.
$39.76 ea. at sparkplugs.com for OEM Densos. I thought they were cheaper than that though. For that price, I would probably forget it unless you get a miss/hestitation.
Not having any problems as of now, so I think I'll just do plugs and wires for the time being.
Thanks again!
You were right the first time, they are pretty cheap. I had the wrong part: Amazon.com: Denso 671-6248 Coil Over Plug Boot: Automotive
And it comes in a set of 3 (so it's not x3), and it is pretty cheap. There is a note on there that says " APPLICATION REQUIRES (3) CAP BOOTS".
I'm not sure what that is? Is that another part I need to buy?
I went with Bosch Platinum about a year and a half ago, and after research I'm going this weekend to buy NGK wires and plugs (Runner is eating up the gas too fast at about 12.75 mpg). I will post any improvements in MPG after I have them in for a week or two.
Thanks for the information everyone.
I went with all NGK when I did mine this past weekend and so far so good, same parts as Brian suggested in ealier post
so whats this deal about a different brands of plugs on each side of the block from the factory? anyone know which side gets what?
(i know one side was nkg and one was denso but which is which?)
USUALLY, that means that a lazy-a$$ mechanic only changed the easy access plugs last time and left the hard to change plugs for the next 'sucker'.* 3 new plugs will be enough to show some improvement for the driver and the average customer will assume that is as good as it gets. Meanwhile, the half-a$$ mech. gets paid in full for a job less than half done. (Since the other bank of plugs would have taken WAY more than half the billable time!) On transverse engines with the back bank smashed against the firewall and blocked by the intake manifold, this is VERY common.
* Also, to be fair, by the wannabe shadetree mech. owner that has not the skills, wherewithall or nuggets to do them.
I'll go ahead and correct you on this one. The Toyota 3.4 in the 3rd gen 4runner did in fact come from the factory with Denso plugs one one side and NGKs on the other. All of our engines came this way without exception. I've heard different reasons for why they did this, but the one that seems to be the most widely accepted is that the driver's side head was manufactured at a different plant than the passenger side head was and they got different plugs installed before the final assembly of the engine was completed.
Also, one side does not take any more time to replace the plugs than the other side side does. The plastic intake tubing on top of the passenger side plugs (the only difference) can be removed in <30 seconds.
I hate 'resurrecting' an older thread; but I figure better this than create a brand new one.
Am getting ready to replace spark plugs and wires and such on my vehicle. From what I'm seeing, if I want to replace the wires and boots, I'd want to order these parts:
Denso 671-6182 Original Equipment Replacement Wires
Does that sound correct? I've already got the spark plugs themselves.
DionicioLives
