Better Late Than Never Build Thread
Just ordered about $50 in new bolts from the local Toyota dealer. If it was rusty or didn't come clean with a tooth brush I ordered a new one as I'm working through some disassembly now.
Also, got the trans fluid changed out and used some Mobil 1 Synthetic ATF I got on clearance at the local auto store. Was gonna use the Valvoline MaxLife but this Mobil 1 is what I put in 15 years and 100K miles ago and surprisingly it didn't look too bad and it was like $6 a quart. Win win.
Power steering is all that's left from a "fluids" perspective.
Vid in 3rd post.
<br>
<br>
<br>
<br>
Do you have a bench grinder? Recently when doing my front brakes, a buddy of mine cleaned up the sliding pins and caliper bolts with one and they looked PHENOMENAL. I can't remember what kind of wheel he had on it, I can find out if you want. But seriously it made the hardware look like new. It was insane.
Heck even a wire wheel on a drill or drill press works great. I cleaned up some lightly rusted junkyard cam bolts that way and they came out great.
No bench grinder but I have a wire wheel lol. My only worry on that is removing the zinc coating and the bolts rusting quickly. Most are pretty cheap so buying new ones isn't that big of a deal as long as I don't get raped on shipping.
Yeah if it's zinc plated hardware probably better to play it safe.
Another option, if you can do a lot of bolts at once, is to clean them up then take them in for plating. Then you'll know they are still OEM. Just be sure to mark each bolt well before taking them in - many bolts are nearly identical but vary by just one thread length.
$100 for a batch of bolts:
Does that stuff remove the zinc coating? Or maybe if they're rusting the zinc's already gone?
It will leave paint on cleans aluminum and steel.
I believe the zinc coating is gone. Hence why it's rusting. :]
Sent from my SM-A536V using Tapatalk
If I did what Spiker did. I have bolts in all the wrong places...lol.
I wonder if you can plate the bolts yourself. As nobody around here that I know of plates bolts. :)
That's a good idea and one I didn't consider. I'm setup as a "shop" at my local dealer so luckily all the bolts I picked up were only like $37 and I probably got 35 bolts give or take so not too bad. I'll have to see if I can find a place around here that does that sorta thing.
And you sound a lot like me, I want original bolts in original locations. No idea why, just makes me feel better. I have lots of zip lock labeled baggies ready to go lol.
Yes. You guys are wise... I mostly do very well....:D
And yes you can plate your own bolts. I looked into it...
Just FYI. You can't buy all the bolts. Some have been discontinued. :(
Life would be easier for me if I didn't obsess over things like bolts. I've spent several hours with simple green and a toothbrush not to mention going blind looking at diagrams and cross references to superseded part numbers :der:
That's the one downside of taking them in for plating, you can't put the bolts in baggies or otherwise identify them. You'll have to rely on photos you take.
I took tons of photos, but I wish I took more. So many of the bolts are nearly identical with a difference of just one thread; some have plain ends while some have those semi-cutting threads; some have flange heads, while others have either washers, lockwashers, or both. I spent way too much time at reassembly looking at my photos and counting threads, then doing the same on the bolts.
On the other hand, I am also obsessive about OEM bolts, and if you are truly obsessive, then it'll bother you that they originally came in yellow zinc but any replacements you buy now will be in clear zinc. Not to mention that yellow zinc has better anti corrosion properties.
Yep most new ones I got from Toyota are clear zinc. I liked yellow better, but clear is better than rusty I guess.
You guys are worried about zinc plated bolts. I am grateful my bolts have heads on them and will still move...:D
Lol you should start a car war that just sprays Fluid Film as an undercarriage wash....Sounds like it would be a hit in the rust belt even if it means some of it get's on the body.
