Big 3 kit is here!
Haven't done the install yet. Hopefully within the next week or so. Voltmeter is constant from what I understand. I suppose its interesting to see what you're running in real-time.
Yes... but leaving it sitting for a couple of weeks with constant drain is never great!
Then again it might consume less than an alarm.
I bought that kit, great quality even though I haven't installed it yet. I already installed a 160amp alt from Quality Power & the factory wire hasn't caught fire yet. ;-)
May not be the best thing, but if it drained the battery after a couple of weeks I feel like there are bigger issues. Im looking at batteries now, definitely need to upgrade.
I read a post somewhere about running the volt meter in the connector off a switched hot. To me, it's useless under the hood anyway but it does look cool.
That looks prettier than my hand made job! But then again, I do not claim to be an electrician, just a hack-job one at best.
Install is super easy though, remove wires, place wires, done. I spent more time double-checking my wire routing then actually routing it. Gives peace of mind and more capacity to adding more goodies like lighting, a thumping subwoofer, winches, etc.
To be honest, I never would have done this on my own. Its part of the kit and interesting enough to be able to easily check what you're running. I wouldn't say its useless under the hood, since all you have to do is pop the hood if you want to check it out. I hear what you're saying though.
anyone know if this kit is still available? I need to get my battery terminals and wiring upgraded after years of corrosion and lack of maintenance from previous owner. I almost got stranded this past weekend.
I probably need this as well.
As far as the install for the stage 1 kit....I assume it can be swapped out within 2hrs? nothing too crazy, it's just wires right?
Ya I wouldn't mind doing as well, if someone could point me in direction to buy.
[MENTION=99491]Bumper2Bumper Auto[/MENTION] was the guy. Great product but he got ripped for lead times. He was a one man operation doing it as a side job while he worked full time. Doubt if he still does. I bought 2 have had them both on for 3 years and no issue at all
Edit:
MARION BUMPER2BUMPER AUTO
This is his website I think. Idk still sounds like he has his lack of communication/ long lead time issues maybe?? I guess worth a shot to contact him because the product is A+
Another edit:
If you guys have the time everything that comes in the kit is available to buy. I remember finding the battery clamps on Amazon. And I can find welding wire(which is just a more flexible ground wire) at a lot of places. Get some wire loom, heat shrink, and heavy duty copper lugs and you can make your own. I made my own cables for my 87 wrangler and my dads 83 CJ7. It was a little easier because there’s a lot more room. Took me maybe half a day with beer to make the jeep stuff. Also it took me about 2 hours to install the Toyota kit I bought and that was with a beer break
Edit:
Another edit:
I reached out to him via email. If I don't hear anything in 1 week I'll call him
After not hearing back from him for weeks, I ended up just buying everything online and doing everything myself. I followed a write-up from somewhere, I forgot but an easy search should find it. I already had a small propane torch, install was alot easier than expected. Good luck
