Saker
Senior Member
Anyone with info on this?
I stated wraps on the drivers side. 9 wraps on drivers side, 8 on passenger. (This is for the FJ Front Coils)
More wraps on the drivers side. 9 wraps on drivers side, 8 on passenger.
No problem.Thanks for the response.
You will need to count the wraps starting at the same location on each coil spring to determine how man wraps are on each side.So from my pictures posted above, does it look like the spring with the tighter wraps is on the passenger side?
I would think there is some technical data somewhere, but I don't have any.Is there any literature on this?
I don't think so, I know the coil counts are the same on both rear FJ coils.Is the same for the rear springs as well? Thanks again .
Most probably the best thing would be to check the color codes on your springs to see if they are the same as a stock T4R!
Where can I find what the colors should be?
No problem.
I'm not looking at my T4R now, but I can tell you the coils on my FJ Cruiser had 9 on the drivers side and 8 on the passenger side.
EDIT: I just looked at my T4R...... It looks like there are more coils on the passenger side than the drivers side.
Measured at the center of the wheel well, the drivers side is 1/4" lower than the passenger side.
Hope this helps!
Alright, so there is one more wrap on the passenger side than the drivers side. Also, the colors on the driver spring is white/yellow and the passenger is white/red. Anyone have any info on this or can check on their 2014 SR5 Premium? Thanks.
