Is that measurement after you drove it around?
Maybe you should start with what setting you have it set at.
Since you got that much lift, sounds like you need to put some 285s on that bad boy.
Springs installed correctly? That would give you 4" of lift....and it needs to fixed.
the spring cups face DOWN (narrow side up) when reinstalling the springs. A couple have managed to put them in upside down. This will automatically gain you a couple inches of lift you don't want.
This makes the most sense, but surprising it could keep it that high. If that's the case, those bushings are REALLY stressed right now!If the suspension was torqued down prior to the vehicle resting on its own weight, that could be the reason for the extra height.
ding ding ding! we have a winner! OP you need to take it back and have them do it rightPicture seems to indicate that the spring cup (black) is installed in the correct direction. Did a shop do the install? If the suspension was torqued down prior to the vehicle resting on its own weight, that could be the reason for the extra height.
"according to the shop" or you watched this being done. Those are really the only 2 scenarios that could cause this unless they swapped springs.... unless your OEM coils are defectiveEverything installed correctly and vehicle was let down to rest on it's weight before being torqued down...
Quote it is done correct, by a shop master mechanic who has done 100s of lifts and especially on a bunch of 4runners, including mine in the past...the lift gave more like 3.25" than 2.5, it still may settle more but I doubt it....I see another post where the guy who put his to 1.75" got close to 2.5" inches so I am not worried at all...it is aligned and rides great and is leveled out with the 1.5" rear spacer
Not worried at all yet makes a thread asking if it is normal...
At the end of the day it's your ride. People are here trying to help out but if you would rather argue about how your guy is a shop master mechanic then that is your prerogative.
