Black798
If you were talking to Hayden ( [MENTION=107971]derpiful[/MENTION] ), he was running 7069s with 1.25" spidertrax, which would explain the fender rub. If not, then ???.
I didnt talk to Hayden about the rubbing he had. I did find it odd though that currently, his 35s appear to be totally inside the fender flares, which was one thing that kept me considering the 305's. But when I measured the 305 width against my current tires it looked like it would have been way outside the flares which I really don't like. Plus they were more expensive and not nearly as common.
The guy I talked to was from Butte, he's somewhere on here but I don't know his tag. His Instagram is @mt_t4r. He was running a 99 limited with icon coilovers, spc uppers, and 7069s with no spacers and ended up needing to trim the sheet metal on his fenders and gut the flares and was rubbing the pinch well area pretty bad. But I don't know what his alignment specs were...
I'm really hoping I don't have to cut the flares or fender and can get away with just trimming off the pinch weld and smoothing out the firewall side of the fenderwell. I've already decided I won't be using a BFH to gain clearance so any massaging I need will come in the form of retubbing. It's more work but I think it will look a little more professional
