Blown HG, options
Wait a second. I thought machine shop checked the blocks?
If you end up with a crack and they didn't find it... time to find a new machine shop.. unless you cracked it in transport back or something like that.
[MENTION=99383]amalik[/MENTION] I was talking about the engine block itself. I believe ( and maybe I'm wrong) that he took in just the two heads. The block is a lot harder than the aluminum the heads are made from, so I believe it's common to take a razor blade to it, clean it up with some acetone, measure it for flatness, then call it good
ohhhh right, the cast iron block having a crack you mean.
right right, that wouldn't be checked. i forgot, he just took the heads (which are aluminum like you said).
Where is the leak?...front, back, middle, exhaust side?
Edit...lemme guess, right outta the front above the thermostat? If so, I know what's wrong
Also, what headgaskets did you use...were they like a stack of thin metal shims or were they the composite style gaskets with sealant applied around all the water/oil passages on the block sides?
Crookedcat
