Brake issue
leo4x4
5 gen 4 runner with 295x70x17
Icon stage 7 kit
My brake padel travels down a lot befor brakes are on, I went to the dealer they said it's normal
I replace the rotors and pads with ebc green stuff and slotted rotors
Also had the dealer flushed brake fluid and replaced with race fluid
Still no change.
Anyone know of a brake upgrade kit with bigeer calipers?
Sent from my SM-G965U1 using Tapatalk
When you replaced pads did the pistons have a hard time going back in? These things are known to have seized calipers.
Icon stage 7 kit
Still no change.
I don't know about pushing them down and them not being applied at all, but I can tell you that they are not super sensitive until they are. So soft sensitivity until you get to a certain point and then grabby. That's my biggest complaint about the 4Runner. In rush hour traffic when you need medium braking they tend to grab and squeal the tires, then when you let off they let off too much. Wash, rinse, repeat.
Icon stage 7 kit
Still no change.
Hi leo4x4,
My 4Runner is a 2012 LE... not that should make a difference! But I don't experience the "Long-Travel/Soft-pedal" issue that you've described. Now you're using a 295/70 R17 tire(?)!
The 295mm represents the width of the tire in mm, and the 70 describes the height; which is 70% of the (295mm) width, or 11.8 inches wide, equals 8.26 inches high from the rim to the ground (my 275/55 R20 is 6 inches high from the rim to the ground)!
That's a pretty tall/high tire; likely giving you a 'GREAT' mpg, but stopping will suffer... there's NO free lunch; there's ALWAYS a trade off! So let me ask you... did you think to compare the brake pedal 'Before' the tire swap? My guess is that this issue started after the swap... just a theoretical guess!
As far as I know, there have been no written-up complaints regarding squishy brakes on the Gen-5 4Runners since I've been a part of this community... that doesn't mean that it is the tires, just that it could be a factor! 'Best to you',
rig
I have a 2019 Offroad and can agree with you that the brake pedal feel is very disappointing to say the least. I also went back to the dealer and had them checked out and "it's normal." Wish there was a simple way to adjust them. Even my 85 BMW E30 has better pedal feel than this.
Edit: the rig is still on stock suspension and wheels
OP said he changed the brake fluid type? Why? Is the new stuff compatible with factory components/seals?
...You must still remember,
The ABS and Anti-skid control Grabs-n-Releases the rotors in 'ms', so it's controlling the amount of pressure placed upon the rotors to slow/stop the vehicle w/o losing traction; which may be why the dealership said that this is normal! ...J/S,
rig, cheers!
Icon stage 7 kit
Still no change.
That's exactly it
That's exactly what I think
I also have a 2019 tundra all stock and the pedal is great.
Changed the brake fluid because the original brake fluid was boiling at stop and go traffic and I would lose my pedal
Hi leo4x4,
rig
I do realize that using a bigger tire would take away from my breaking a little bit however I've had that problem even when the car had stock tires
Your original post mentioned replacing brake fluid with Race Fluid. I'm not sure what you mean.
At long lights you could switch to neutral. Is there any other mods that could contribute to heat soak issues?
Edit: just saw your pic with Supercharger. This can add to heat soak problems. Especially with Stop/go traffic. How much do you weigh with all of the mods? Have you upgraded the cooling system?
6000 lb
Have not upgraded cooling system
If you had a lift problem this is the correct forum ..
since you have a low brake pedal not gonna get much help here.
IMO since I have worked on vehicles that I do repairs not lifts and other modifications your problem is the master cylinder . also mixing different brake fluids and brake fluid boiling sure can damage the master cylinder .
good luck ..
My assumption is that by "race fluid" they probably just mean ATE Type 200. This is just about the best stuff you can buy without diminishing returns of something more expensive like Motul.
And maybe i'm not following the thread well enough, but why are we talking about engine heat soak?
I've noticed that I have more brake pedal travel now, but I think that is due to the fact that I'm over 50K miles, and due for new pads/rotors. My bigger concern is the damn brake assist. Any time I hit the brakes a little more quickly, I end up in a panic stop. I'm guessing there's no way to disable this function, right?
AndiGarage
