Brake pad and rotor change - scratching noise...
jlnorsworthy
Because I had pulsing when braking, I changed the front brake pads and rotors. I changed the rotors one at a time so I could verify which one was causing the pulsing (left side). Now, the left side is making an offset scratching noise (it's not constant, only rubs on part of the rotation). I have tried both new rotors on both sides of the vehicle. The results are consistent, scratching on the left side. Forgive me if it is obvious, I'm a bit of a noob when it comes to working on my vehicle. Does anyone have any advice on where I should start to diagnose/fix this issue? The vehicle is a 1998 4runner, 2wd, 2.7L.
Now, the left side is making an offset scratching noise (it's not constant, only rubs on part of the rotation). I have tried both new rotors on both sides of the vehicle. The results are consistent, scratching on the left side. Does anyone have any advice on where I should start to diagnose/fix this issue? The vehicle is a 1998 4runner, 2wd, 2.7L.
Is it possible the pad wear indicator is rubbing somewhere is should not? Did you replace the anti-squeal shims along with putting some backing anti-seize on then?
edcultural
