Brilliant's Mod Thread
Project Un-Limited
Made some good progress on my unlimited...I am also planning on painting the bumpers body color.
I practiced on a the limited door I was replacing before going under the 4runner and welding the rockers. I used a millermatic 211, no previous welding experience and was able to weld the sheetmetal.
AIL4fc-MTEQQgkDd-7lSro0GWiDhMa0jmC_sP3u6VByME_-ui8Ga5ajpixDqo9gCA-RqY50k_clFiymUXwUhUamHQYa23KT93vKAUVDiEgGiJpEV7D1rL6Yy6wC4YHtdBu7zCLFKE95jZKGpiGI1nljxlwE-qQ=w1521-h857-s-no
AIL4fc-p7snkPL_mTkZg6i3itOxDetE81bcxTYSv0qR0QRMppESaATf-DuO9KHy593_mlSQqFOhzKcFnK55iMSehxNydp4rfbYDOwcsHt10H06RwAjghNpSrr79qdFTpGvoVqW9Dc5alTQ4tpuxxZSGYXtZFbg=w482-h857-s-no
AIL4fc9JrW7ToQdKjkSCqGkC0xlxlcJ6Hd53VSPM256UPH3BIBoT4YcR6LECxo8Ae3n0lLxN858uHfnzO5Omcun_fhpcruDpclCEBE-3En33nrcbbvGU4TcJT7FJKnAwWVK0JF_e1TFs00GfuJPQ1x4KImYDTQ=w1521-h857-s-no
Going for this look.
AIL4fc9lSKdZ3t19JIjD8B8XO-atXaNgLZUt-_kugevB0TGuhQDCl7Xs_vcJg2nDpqslCFqbQrPpHYCSXtO6U1CkBmLHvbRoMKKJQ6OCIrkl-hQnyc4aK_G1VgEmK5GzrLh1eS4-FLui7Pm8DrWPfkZ94voJkw=w1024-h768-s-no
The rear door I picked up ended up with a cut harness from the yard, so I get to enjoy fixing that. Front door, everything works, so it went in easy.
In the garage, with the door open, it's close to the same color and doesnt warrant painting. In full sun might be a different story. We'll see once I roll it out with the other side one. One of the doors is a bit rougher from another truck, but clean enough to start with. I have the desert dune mud flaps and rear quarter trim as well.
Looking forward to seeing your paint work. I like the look you're going for as well. very clean.
Good luck with the paint and body work.
What do you plan on doing about the holes in the rocker panels? It looks good. The fully Desert Dune 4Runner is actually a Canadian-only package from 96-98.
Looking forward to seeing your paint work. I like the look you're going for as well. very clean. Good luck with the paint and body work.
Thanks, its good to have a nod I'm doing the right thing
For the rocker, I intend to weld them. I've talked to a couple shops and that's the right thing to do. The material is thicker on the rocker so it should easier to weld.
The candadian only makes sense. I've only seen it on canadain owners or japanese surfs. I did more research and it was the 'badlands' edition.
Center Console Panel Switch and Diff Lock Switch Panel
Objective: Add two switch slots in the lower dash, add another diff switch for front locker
What I did:
  • Sand down a spare bezel with 400 grit in the area
  • Obtain an oem switch panel and cut it down to fit
  • Using CA glue, position the cut down panel in place
  • Tape the front side with masking tape, fill the back with epoxy
  • Apply filler to the front, shaping and sanding as required
  • Paint with high fill primer and decreasing to 600 grit for a smooth finish
  • Paint with black trim paint
  • Trace diff switch outline on plastic
  • Using a sharp razor, cut out blank
  • Epoxy to the backside another switch panel to provide tabs for the diff swtich to lock into
  • Remove diff lock switch face
  • Using an exacto knife, and a light to backlight the face plastic, remove part of the R and form an F
  • Replace face and wire as required to operate locker, tap dimmer circuit for backlight as desired
Wow, this looks terrible
AIL4fc9IeLzgVpHzZRnfsg6hKwkWyUFjsgGALXE8d-T447KNQVvtv6_y9pF1U5KFnIvCEWZvSmnUMgLKdwsr9UIpKdKaOqjpWu1yXCCNsuRla9qr4wqeJStUKpYyQ6GTUV22c7gjiEMLKzGoOToxTpIyucWsGw=w1521-h857-s-no
Getting better
AIL4fc9HwEVrsL7-w-gfNSrNsc7McDzB4V0PIm6vhK-GJscbESwwL9QN77geEte8t4Xu7myxDmaifQMyuK1V1f6HpzGC7t4XxT2BNJ3Vr5KNn-BaudMXliF_BG3uzrJZBK1rK6dkF79OPKYD2xmVhPknz0WFZg=w482-h857-s-no
Turned out good
AIL4fc-_vIyMPYn2hJ7a40pvBBRS9HSSB2UizOyr7tm0CR9xt_OWbf1-BbuhRF6Y6DhLk7CDNvY2pqPIrAmXRd1rjCbh-i3ovxHlxTgkL7NaUoyw5BdX6c0NH-ezM6oURajUI_m24oTpcQt6isMGUTfQmpumIA=w482-h857-s-no
Backside of panel
AIL4fc8tNeseNUqsfN-aoEFPEBYEC0lzNzDaXH8Te7K3wwvxddSfAWKpU7IlmVIt8AAOlNRA1E8reeLYTQAegw1_VJciiN_Uls-1kXl3EYltrXe0b29jQY_oJcRsaUbmbqEG7_d9zN2_8OaKF7uTYDU3Jlb1Fg=w1521-h857-s-no
Panel cut out
AIL4fc_7522SpI4YL02x263nKywiIXfI4PXeMK_CktzgoAkX_NG0JAsUvWy50dqh1wta3P9sP4tsg__VV-HK4szuE6u-bLRdr71PvHibXdpKYX8qyjEL38KInYVm6M7bV-9Rsui9BRWN4f5v-zwAFSeYnVtj4w=w1521-h857-s-no
Diff lock switch face modified
AIL4fc8Z4A30WuQEE0veU1q1nbWhJEP72xYZ1nvMQPCCCEdpqj1JnXwIiBhOOJP9p33wmMHD--9JAO-0ekof6lEFQGm9hFsIsShZeEnZPWm4RajrrLs7RKUeRYMajgVncX8Pt0iW14Ynnw9JJSswk-JNSXPyHQ=w1521-h857-s-no
Installed with dimmer connected
AIL4fc9pF_Bpr0REh4M4I9vGuhXu6uUI5UvaCu2G7g2lAPLIEICCKmklXnot96uYKUmlLQCAuyPhBnu818Q3D8SxQwwiCJ6thYrSMAPPoTxQAondBodeUo--_-DMRC3Vo8RLfZ3e0nfd1YdMZSPUlxKyRBgvNw=w482-h857-s-no
So... Front Locker to come...?
What do you have planned for the other two switches?
The two blanks are just to give me my din back. I'm looking at a double din unit.
Yeah, front locker is coming at some point, but not sure if before a winch. I had to back out of something I was pretty sure I could do but was alone and the walk was too far if I got stuck. I got a winch plate and a new piece of Tupperware to so if I can do something like this taco cleanly. [MENTION=94189]hurt4x[/MENTION] and [MENTION=85167]jmildoc[/MENTION] have done it so looking to copy them a bit.
M8000 Hidden Winch
Objective: Add hidden winch, be able to do straight pulls to get myself out of trouble. It uses the oe pull points
Process:
  • Pick up a jeep winch plate from rough country, 87-06 wrangler
  • Cut off frame caps on 99
  • Clamp winch plate to bottom of frame for reference
  • Cut core support out to make room for winch
  • Cut out front frame c channel (you're replacing it with 3/8" plate)
  • Remove core support bolts, fabricate support that rises up to clear winch. I used 1/8" plate for feet and a piece of 1/8" wall tube, bent
  • Grind down backside of channel on winch plate
  • Fabricate new AC condenser brackets, moving it back 1/4"
  • Cut off tabs from back sides, weld in extension pieces to reach recovery point holes
  • Cut tabs to reach around frame rails, drill through
  • Put in tube spacers inside frame, bolt through
  • Put bumper back on, cut out plastic for fairlead
  • Cut out minimal amount of valance to reach winch clutch
  • Mount winch box on frame rail
  • Wire as desired
Getting dimensions sorted
AIL4fc9qTb-fpuDYkCVTcJeaQXGz9k0v5SS2LoZU_osKtsq1fcbuh6orAVS2AFl525XhBcmN5pxCWddmhjoMzC5QAaJwst0iNOaiYkBPSWnRBTgw6p58C0b1EK40zFmujUH2BYIm9-I6LAVuLsdqMuU5aINB5Q=w1521-h857-s-no
AIL4fc85Ezvk01OsqetFviaZja8f8OvSORfUBtyJWx5kiEI6c8SlgVfmOwmpj121-W_GOA3CfFIeMFBg_n-9JRosUZRmjca4RyScs_NdIpIKQUBT77mMFU6f88TSXa41G5ZbgbDvGdoAUy7KsodNcYbwMHV_IA=w1521-h857-s-no
Replacement core support
AIL4fc-Y4UcweYfUjwxFn5Y1Cuvc6FcMBxW0wfNdfXoh5JHiHhDqiDmeuZruOL52iaj8zroqWtwBCkt2T5K4guOIIxFTEC_VPsDPIZk8e-5HTHmKjKfsYyTLdl-_bsxlbxa5DQSCpFWTthRwrUxSJg3K6lyuHA=w1521-h857-s-no
Mostly together
AIL4fc80ik2tQs7WAO70g_hYPHATsM7oUfCZOFxiflhiK-MRHftuz4l92TUxCzbalPaql5UQcj22Ja7RmleTasEM263mhy5ZVC55nJgOkGXTZPn5A64Lb1jP8CoN5zBUyHRzX1CgrnbkVxFtH-zJw2vYZvP7gA=w1521-h857-s-no
Control box mounted
AIL4fc9tt2FSZAII6h4Uf2n8QmZ-YfLbpLoVNof6QU36zRyyN5iubLXYNjDqZvzQPbOazGnrt5JRKmt6VmNMHMzcbqm9xr9DXhhp5oJ88dX-PSlZlwRvVQ1S26jwmjRolX68IVWKl3jNdioQxyUNP4gJge-E6Q=w1521-h857-s-no
All done
AIL4fc_MF8ifGhRnt6LlkZW_flDpLO19EtALKwR9-EjHjMfXsumG5qOfTRObXzlFirlhsBBSlOEraIq40lvfXmRd4JJOwPFDx8cTOQIeaKVJG1M-xH9m9dP3zTB5vPcw9PgjITa6X2L1iZgQm3xzPZWvwGvCIA=w482-h857-s-no
Ah, cool. What are the specs on it?
M8000. :banana: More than I need, but expect it to always work when I need it.
It ended up cheaper the the VR I was looking at. The huge selenoids on engos werent an option for my space limitations and swapping them for a contactor was ~$100 upgrade from what I saw.
Black FJ Whees
Thought about getting some new wheels, but I think I like this style.
I pasti dipped them to see what they would look like black. Going to follow up and paint them black.
AIL4fc_Tde5-ZeuRjZk80pRvZzA9PDOcNX8B9Lqoda5lLerxXd52I9k7_2fjf21OYCLEkZMeEvSPXluOimNfTwkbjQANERfI0PGqy7_gbQHWxM_AeAEmSDXci3oZto5wUcX7KVbnyGIiMPxJG5LNI6ZdPTKwXg=w499-h281-s-no
I found this on the FJ forum. I might do this, but I'll look for some sort of flatter cap, like a blank tundra cap if it fits.
I also test fit the black TRD caps, no so good style wise. I tested tundra flat caps, and they fit. So I painted them black and swapped in some black lug nuts. .
AIL4fc-f_F_HxHyYnZp8LtSmWicdQnJ95EN3Qe_obW5KU4XqfJ3OQM0nLL2mkdB-UHGxOvQHmjHYHPshneRVnLTQZnjqCJ_gPae_5_u629fVquTd64FBvy1hfCTg89F3gaap-Js-JUIF_zxV1N6TZL9mXf93BQ=w482-h857-s-no
AIL4fc85lmn9AprDhyUJjr77ycCv_fmc8fLiheOoJRoBG3llUMA-5as0rs5UA2ICmo6NpqzJbjtna-wcuWacuG28Fw7TUfDamFcxTtmSMH2IPtRHd5uOwLbPuowqlF9oMOQfFlmfeNoF8ISmWbB4n4ycNJFhMQ=w482-h857-s-no
Final product with some ebay decals
AIL4fc_lp15Cnx_JfHo0tCEJnoI36tEFWwEb9K3eCp8FB4e_jieP7SHGGLNqJHufTIz4CxmnJlsprCDwSDK62prJ_FMwoXOqLb9XOsttiCgzwtlRgUtKmC1vFcQPNTLCEW4mGEjb7AtVq986Ku6s9S_nubabpA=w482-h857-s-no
I like the extra switch blanks project. Especially since those little cubbies are absolutely useless. I might try to snag another trim piece and attempt doing that myself.
Good work!
Got the final door in and on today.
I also got some 255s in from ebay discounttire. Not sure how they will work with the sport flares but I'll mount them up and see.
Like most things, hit a snag. The electrical doesnt work in the door so I am going to swap the harnesses.
Got the door eletrical fixed, mirrors, and internals swapped. Everything's working and ready to go. Buzzkill last night was I am still missing a flare peice. Somehow I forgot to get the front right bumper peice.
Group 31M Battery
Posted another thread asking about a group 31 in their 3rd gen. I found a thread on it on yotatech and he'd been running it for years so I went for it. Ordered some new terminals and new terminal covers.
Dual batteries under the hood - Page 4 - YotaTech Forums
I thought I could use a slee hold down with minimal modifications. Didnt work out that way.
Before I modified the slee tray, I checked for clearance. 1" would give me piece of mind. Good news it was an easy 1.25 from the terminal to the hood. I wont use the main terminal as the other post is rated full load I dont want to replace my cables right now.
AIL4fc9f10fZSPw2Vk3rIxNe9orRPubaHX4f5bZ-8lSZX_SnRwm_L8Hn1It_o0IIpbpyO4nGkKNXjQ2O6z5MRS615yTGnuRi6v1yc_6E_4IaJcClstHDvp3COmwZ44q7GLXMo7sVpOtlt0ECjw_Mp5vm1s49Tg=w1521-h857-s-no
The slee tray is too large to snugly fit a diahard platinum, I bend the edges to 90 degrees and tacted a spacer to the side. I added a longer strap and bent the strap to a new angle.
The next thing was the need for a longer J hook. Some 1/4 rod bent over a socket extension and a M8 dye made a longer hook for the taller battery. The OEM one was maybe 1/2 too short.
The final modification was a 10cm spacer to the side to grab the battery tighter. You can see the spacer in this pic. Slee wants you to use some foam, I wanted it snug.
Smart led battery monitors, green, amber, red flashing as voltage. A few dollar solution and less crap hanging on the dash compated to other contraptions. Gammatronix 5mm LEDs.
AIL4fc9JyT4VnP8V5yqGvxHQqZnvlZnEZuCEb1R-Q9wZEzkPMUAA1xN9yy_c-LAAubR9QNjmvDfgqO-WGFsMxjboFlssyjg7Grin23GVgbccJH_80OO3NkLXj_yfn9i8easnryZ0hPd3oXyzfq1uep9TK5jr_w=w482-h857-s-no
I also went to the junkyard and tried to snag that flare piece, bad news they got rid of 4 3rd gens they had and one of them had the flare I needed.
You should put off your winch install and sell it to me... These Icon 700lb springs need some weight up there. haha
No replacement winches worth looking at locally...
Sliders
Set these up for looks, motivation to get this done. It's going to look alot shorter with sliders on.
AIL4fc8jlPyAbx1yAv1-pfv5Jgm1jt9ItUSoLCvSy6c-DgIE6GlTKTRERdBJr_N_jVKDlm1Wx5FyMsapI_hQd-OYwCp_tvPeObhPPSfSbzd4lJf6ZaQQ_zEOjwxaloqSKft_vaiznZ-PmYDmC2cng4KABiWppQ=w482-h857-s-no
Saw in your thread you winch was jacked, thieves are the worst.
Very nice work man! I think I'm motivated to add those switch blanks there. Not that I'll need them ever but it seems like a good wintertime project to keep me busy.
looking good. i'll be needing a new battery before it gets to cold as well. looks like you'll have two providing plenty o power when necessary! :becky:
erinobr2000
