phattyduck
Elite Member
Yes, that's exactly it. Pay attention while accelerating on to the freeway - you'll actually feel/see 4 'shifts' on a 4-speed transmission. The last 'shift' you feel is the torque converter locking, and acts like a '5th' gear. At that point, applying more or less throttle (to a point) will keep the engine RPM locked to road speed. When the torque converter is unlocked, engine speed can/will go up and down related to throttle, not just road speed.Thank you again for the detailed explanation. Can you tell me what is meant by a "slipping" torque converter? Are you saying that even if the transmission is staying in 4th, the torque converter may still not be fully locked causing it to generate more heat? My apologies if its a silly question but I don't know much about automatic transmissions.
And unlocked (slipping) torque converter is how the engine stays running while stopped in 1st gear, how gear changes are smoothed out, etc. The slipping is good for smoothness/control, but bad for efficiency (most modern high-gear-count auto transmissions lock in every gear but 1st).
-Charlie
