Can you identify this unplugged part?
c2one
I have a '13 T4R and was installing an AFE CAI and noticed that something was unplugged.
Can you tell me if this is supposed to be like this or am I missing something. What is supposed to be plugged in here? Just bought the vehicle 3 days ago.
Any information would be appreciated. Thanks!!
This is the area right behind the air intake. (back left corner if you are standing in front of the vehicle)
close-up (I know I never unplugged anything from here)
Note: I tried searching for this but I am not sure if I am using the right words in my search.
This looks like the connection to the MAF sensor. If you look at your old stock intake, in the middle of the pipe, there should be a connection for this. You will need to remove it and attach it to your new AFE intake.
On page 14 and 15 - http://www.vividracing.com/catalog/productdocs/AFE_54-81932.pdf
This can't be correct, only 1 red wire...
I'm 99% sure this is plug RA1 which is the power source for the factory 400W Inverter. Best i can figure using the diagrams available- BUT the plug color, wire color, and general location are a very good match.
[MENTION=98089]c2one[/MENTION] I assume you don't have a factory inverter, correct?
[MENTION=84192]phx[/MENTION] My MAF sensor on the AFE is all connected. Already got that up and running, sounds good too. I appreciate the feedback.
[MENTION=65614]Antman[/MENTION] I am still getting to know my 4R, if the factory inverter is located in the center arm rest... then no, I do not have it.
Thanks [MENTION=88447]kenski[/MENTION] and [MENTION=65614]Antman[/MENTION] for clueing me in as to what this is!! Don't have a use for an inverter currently but good to know I have options.
It is the power wire for the inverter. I have the same wire, and no inverter on my 13.
Indeed it is. When I was dynamatting, I found the other end comes up through the floor behind the passenger side rear tire - it feeds the DC>AC inverter mounted on the passenger side rear wheel-well...
:cool:
That was my thread and as [MENTION=65614]Antman[/MENTION] stated it is for the inverter.
I think that plug is the 2nd picture in this post:
http://www.toyota-4runner.org/5th-g...ed-but-couldnt-find-answer-identify-item.html
Looks like someone was able to identify it in post #9, #10. Can't blame you for not being able to find that in a search. I knew exactly what I was looking for and had a hard time pulling it up.
These snozzberries taste like snozzberries.
