Cargo box with Baja utility rack
Haydenatx
Member
Does anyone have a baja flat/utility rack and a Thule/Yakima cargo box? I am looking at buying one but not sure on fitment. I'm trying to avoid having to buy the Baja round bar adapters. Any info would be appreciated.
I'm running one here on my Bajarack UT rack with the Yakima/Thule adapters.
The box will not work without the adapters. An alternative would be running the Yakima rail grabs which will allow you to mount the Yakima cross bars- essentially building another Yakima rack system on top of the Bajarack. I thought about this when I wanted to mount the cargo box with a snowboard mount.
Truck looks sick! Thanks for the info. I will go ahead and buy those adapters. Cheers
Never mind, figured out you were using mounts from Baja.
I wonder if the Prinsu could be configured to hold a cargo box...
Correct, using the Yakima adapters from Bajarack but the added height was more than I liked. Unfortunately there's no other cheap way around using them though.
For the Prinsu, I believe the rails are removable so depending on the width of them you could possibly mount the box directly to the rack.
goddesszilla
