Cargo Power Port Part Number needed
Asmara
Does any body have the part number for the cargo area power port /power outlet (aka cigarette lighter plug)? I can't seem to find it in my part number book. Specifically, I need to replace the cover assembly which has broken off. I'd also like the number for the port itself because I may stick another one in someplace else.
Thanks.
It may be easier and cheaper if you just replaced it with an aftermarket. I've used these, and they are very nice. It can be mounted with or without the square faceplate.
12v Flush Mount Receptacles & Plugs Single
I've seen that one before but I generally like to keep everything looking OEM. The other thing that I don't like about that one is that it doesn't have a real hinge like the factory one. I'm not sure how much the cargo power port cover is but the hinged power port cover in the center console was only $6.50 (which, admittedly, was shocking).
Found a dealer with diagrams online
Just to close out this thread. Here are the part numbers.
Cover, Power Outlet 85535-35080C0 approx. $6.50
Socket Assy, Power O 85530-42010 approx. $28
I know this thread is old, any steps on how you replaced the rear cargo "cig lighter" outlet? Thanks
