center console swap/cupholder mod - plug'n'play
hrt4me
I recently followed the directions in these various threads to swap/upgrade the center console in my 1996 SR5 to one donated from a 2001 SR5:
Bob_98SR5's Cupholder Mod
ToyotaWiki's The "Cupholder" Mod
My '96 had the rear heater, and I got a donor center console from the '01 with a rear heater, so all those corresponding parts matched up nicely and were an easy plug'n'play swap. I only had to relocate a single switch (rear window up/down) from the front of the old '96 center console to its new location in the dash, left of the steering column, which proved very simple and straight forward given the easy-to-follow directions in this thread (I even rewired the switch to reverse the up and down positions):
Cup Holder Mod - Center Console Upgrade
I used the complete eBrake assembly from the donor 2001 SR5 because I did not want to have to drill and tap into the tub of my own 1996 SR5 in order to pivot the front of the eBrake ~15° toward the passenger side; the only modification I did have to make was to trim the 'eBrake cable stay tab' because the tub to which the eBrake attaches was different on my 1996 (narrower, on the left) than the one from the donor 2001 (wider, on the right):
P1000994_zpsd2919e31.jpg~original
P1000997_zpsffd72d49.jpg~original
P1000995_zps090f5f35.jpg~original
Finally, the only issue which initially prevented this from being a true plug'n'play installation was the difference in mounting brackets. The bracket is mounted to the tub of the truck body via two (2) 12mm bolts, then the black plastic bracket which holds the rear heater sliding lever is affixed to a raised portion on the rear of that bracket via a single 12mm bolt, and finally the center console itself mounts to that bracket via two (2) 12mm bolts through the deep storage tub of the center console. The bracket in my '96 was silver and relatively longer; this is the bracket which Bob_98SR5 relocated back ~ 1½" by drilling and tapping new holes in the tub of the truck body, and which Asmara bent using a hammer and vise grips. I was able to get a spare bracket from a '98 and tried Asmara's 'hammer and vise grip' method, but I just could not get the upper mounting holes to properly align. So I stopped by Toyota of Dallas and ordered/purchased the corresponding bracket for the 'newer' 3rd generation 4Runners, thinking it would be sufficient for a plug'n'play installation, but I found that even though the silver bracket was relatively shorter (than those from 1996 to 1998 versions), the upper threaded holes used to mount the new center console itself were still not in the correct location (still ~ ½" too far forward). A little more digging yielded this thread:
need source 1 small part for cup holder mod
and I was fortunately to find and buy a yaw rate sensor (with its corresponding gold-colored mounting bracket) for only $10! When it finally arrived, I was able to bolt the gold bracket to the tub of the 4Runner, and then the upper holes lined up perfectly to bolt the '01 center console to the gold bracket without the need to drill and tap anything.
So there seem to be three (3) different mounting brackets which attach the center console to the tub: the longer silver one for 1996-1998 trucks, the shorter silver one for 1999-2000 trucks, and the gold one with yaw rate sensor for 2001-2002 trucks. Here is a photo of the three for comparison (1996-1998 on the left, 1999-2000 in the center, and 2001-2002 on the right):
P1010029_zps0a77d66e.jpg~original
and here is another view of the three brackets, in reverse order:
P1010027_zps9c6ac33d.jpg~original
This leads me to assess that Toyota must have also produced slightly different black molded polymer center console inserts, because the mounting holes are in slightly different locations in 1999-2000 trucks versus those 2001-2002 trucks with the yaw rate sensor.
The bottom line is that if you truly want a plug'n'play center console swap/upgrade without having to modify your 1996-1998 truck by drilling and tapping new holes in the tub, then make sure you get from the donor vehicle the complete center console, eBrake assembly and corresponding mounting bracket. Hope this helps someone looking to do this cupholder mod in the future...
did the rear heater duct fit properly with the console? because the rear heater assembly of the 2001-2002 4Runner are different from that of the 1996-2000 MY.
after I cut and trimmed the new 2001 center console according to the write-ups, the rear heater duct seemed to fit properly, but I have never used the rear heater, so I guess I better go back and double check its fit to ensure I did not inadvertently cover up something critical... do you happen to have pics of both model year rear heater ducts for comparison?
no, i don't have pics. i think the main difference, as far as the console is concerned, is the right side because that is where the difference in the rear heater duct configuration is.
Also, why did you trim the console? i think the reason why others trimmed the console was to fit the console into the old bracket. but if you have the same year bracket as your console, then there is no need to trim. everything will fit right away.
also, having the console box higher is more comfortable
<img id="ums_img_tooltip" class="UMSRatingIcon">
I started my conversion/upgrade project by following the instructions in the various DIY write-up links to which my initial post referred and was trying to use/modify the original 1996 mounting bracket, but when that ended up not working/fitting, I then bought the other shorter 2001 bracket from the dealer (which also did not bolt up perfectly)... and then after more research I learned that I needed the gold colored mounting bracket for the yaw rate sensor, which did indeed bolt right up without modification. Had I not been able to fortunately find that part so cheaply, then I would have had to modify/bend the 2001 bracket slightly to make it fit, but now I can return that part to the dealer for a refund.
In hindsight, I would not have trimmed my console with the correct combination of parts on hand initially...
i just finished mine this weekend, i have some additional info on the brackets. I bought a 2001-2002 bracket from villagetoyota.com. I ended up needing a 99-00 bracket that i found locally at a junk yard.
The bracket is $41 and is part # 5890235020 and does not include the yaw sensor:
I just finished mine this weekend, I have some additional info on the brackets. I bought a 2001-2002 bracket from VillageToyota.com. I ended up needing a 99-00 bracket, which I found locally at a junkyard.
The bracket is $41 and is part # 58902-35020 and does not include the yaw sensor:
that's the same bracket I ended up using, to which Toyota originally mounted the yaw rate sensor
when I did this modification back in the Spring, my local Toyota stealership proved no help in identifying and ordering that bracket for me (I did not have a part number, as you did), but I luckily ended up finding online a used one (still attached to a yaw rate sensor) for only $10, serendipitously saving me $31 apparently...
Thanks for the write up! I just finished this mod today.
I’ve got a 97 SR5 and used a 1999 center console, bracket, emergency brake, and metal tub insert.
Plug and play
I hate to revive an old thread, but I pulled an e-brake tub and all other parts out of a 99' and can't get the emergency brake tub to fit on my 98'. Has anyone successfully fitted the newer style brake tub to an older third gen? Or does it have to be redrilled/have the sides hammered to fit? Any help would be much appreciated!
I did it twice for each of my 97s, using the ebrake and the tub from 99 models. Both times I had to trim the hole about an 1/8" so the tub would fit.
Ream out the hole, or you can take a swazall to the side if the tub, just under the lip. Only needs a little bit to fit in.
I used the '99 tub, but had to widen the floor opening by about 1/4". From my writeup:
...When you put the ’99 tub in the ’97 opening, the holes don’t line up:
I layed out the size of the larger opening that was needed and got out the angle grinder, as suggested by others:
I hit the bare metal with some POR15, and was ready for tub installation:
Here is the tub installed:
Thanks for the quick replies
Ream out the hole, or you can take a Sawzall to the side if the tub, just under the lip. Only needs a little bit to fit in.
What do you mean by the side of the tub? Do you cut through the bottom/side or just the side? I didn't think there was enough material on just the side to make it fit, but that sounds pretty simple if it works.
Thanks for taking the time to post pictures from your writeup, that looks pretty easy to do. Would silicone caulking/primer work for sealing under the body? I found rust under the rear bumper a couple weeks ago and I'm kinda paranoid about this stuff now lol
H.Sikina
