Changing head unit to kenwood DDX372BT 6.2" screen/ do I need a harness
Whoknows1120a
Hey guys, I'm new to the forum and can't find anything really specific about this. I have a 2004 4runner limited with jbl sound system. I only wanna have to tear into my dash 1 time and get this hooked up correct with all the right parts I need in front of me if possible. I bought the kenwood head unit. Now is there a special harness besides the steering wheel control? Will I need a dash kit? Or a bypass harness? Any info is appreciated.
So i need the 124 dollar kit? And the Metra harness? The kit just says it inclues "the wiring" they aren't specific. I have rds. No navigation.
youll need the JBL interface harness to get your set up to even work. Also youll need the bezel and the harness it comes with to hook to the JBL interface harness you are going to buy.
I just bought the identical unit for my 03 with JBL, from Crutchfield. Included a wiring harness, dash kit, and steering wheel control interface. I haven't started installation until my cheapo eBay rear camera arrives then I'll tear it all apart. Crutchfield did send an installation sheet with some wiring details. I'll attach a link to the .pdf below
This is great, thanks man. I'm about to undergo a full stereo system swap. Do you have any other guides like this? I'm completely going around the factory system with a new headunit, amps, speakers, etc.
No, I don't. If you are replacing the factory amp then it becomes easier I think, some good write ups on the board of similar project builds if you search around.
Whoknows- if you go to the Crutchfield website and type in your vehicle and/or the HU it will let you know what all you will need to do the install .
Check out my signature for a list of what you want. I put a Kenwood double din my my JBL system.
The only thing I might change is the steering wheel button controler. I just helped a buddy upgrade his stock stereo and we used the Axxess brand adapter instead. It automatically programmed itself which was much easier.
AndiGarage
