Cheap 4th gen snorkel option from Australia
Did you had to use a heat gun at all ? Also did you notice looss of power at the top end? It feels like my truck lost some. But since I used a heat gun, i think that i squeeshed inner diameter of the pipe to the point that it created a partial restriction
Sent from my Redmi 4 using Tapatalk
I didn't use a heat gun at all, I actually thought of using it to straighten the head of the snorkel but kinda of grew on me. Lots of friends had issues with branches breaking there's except me so I left it that way.
Try pushing snorkel head bit harder so it wont have that incline.
Not at all, I'd does make intake sound alot better when I floor it. [emoji23]
Have somebody rev it and put your hand or a plastic bag over the snorkel head to see if there is suction.
Here are some pictures from my initial installation
Snapped a few pics for reference.
Ok, so its not as bad as i thought initially.
To compensate for a different fender I got a door seal from amazon, also i bought 3,5 inch intermediate pipe and 90degree elbows instead of squeeshed piece that comes in a kit, also amazon, dirt cheap. Also if anyone get this kit, make sure that after gluing door seal between snorkel and fender you tighten bottom nuts first. Then it will align nicely.
Nice job
Thank you!
But i will take it down again in a month or so when those silicone elbows show up. I think engine is choking on that intermediate pipe.
Thank you!
how is it holding up?
mine has been lying around in the store for awhile. tried installing it today, realized i need a hole saw.
the kit i received appears a lil different from yours, or is it an improved design?.
Snorkel kit Fits Toyota Landcruiser Prado 120 series Petrol/Diesel 4x4 2002-2009 | eBay
thats the unit i bought
Mine looks good no cracks or anything. I very happy with result. How is it different ?
ok, seen now, you bought some other pieces from amazon to make it better.
gluing the door seal, you talked about, am a lil confused, so you had to glue something again, what type of glue did you use?
am about ordering a 95mm hole saw, so i can start the ops. any final tips you can give me?.
am putting mine for the looks, dont plan going into deep water that the stock air intake cant handle
So the rubber seal has a 3m sticky tape already. I glued that to seal around the base of a snorkel to stop water accessing drilled sections of a fender and to hide gap between fender and snorkel. Oh, don't use heat gun I tried and had to purchase another main pipe. Make sure that you align the pipe and mark where the bolt holes are gonna be and the main pipe hole.
What may happen, after bolting a snorkel, it will take few days before main pipe will start flexing/adjusting to fender and a-pillar curves, so I suggest to tighten snorkel just snug at first, drive few days, then tighten all the way for best fit. I didn't drill a pillar, just trimmed the black metal bracket and bolted it to snorkel pipe only and glued a piece of rubber seal between a bracket and a pillar to stop pipe rubbing on paint.
I hope all that makes sense
Safari now makes a vehicle specific snorkel for the 4th gens: V6= SS445HF and V8= SS440HF.
It's not worth the headache of adapting one to our trucks anymore.
yeah, it makes sense, however, i didnt see the part circled in green in your write up. itd in my package, and am a lil confused where it goes.
@ Pierre T4R it goes for over $500, a bit pricey i must say
I did not use this part, i bought aluminium short pipe for better flow and 2 more 90 degree flex silicone hoses.
This is how it looks like now, i also turned intake head other way because too much mud and dirt was being caught when I was punching through mud pits.
Well, it looks like prices have doubled on alternatives and the Australian merchant no longer has stock.
yet to install mine still:frog:
would you mind posting the link for the exact hole saw you used. been searching through amazon, conflicting reviews on many decently priced hole saws
I got mine a while back from amazon, cant find a link anymore. It was a 95mm pilot hole saw i think. I can tell you for sure on sat when i get to the shop.
lol, have refreshed this page over 5x today already, was hoping you ould not forget.
seen it on amazon, guess it was among the cutters i skipped, cos of not too good reviews.folks complained it was a one time cutter:surfer:
HSS BI-Metal, DEEP Cut Hole Saw with Arbor, 3-3/4" - 95MM Diameter: Amazon.com: Industrial & Scientific
guess i may pick a bosch or a lenox cutter instead
I use Lenox brand hole saws daily professionally, none better IMHO.
Amazon.com: LENOX Tools Bi-Metal Speed Slot Arbored Hole Saw with T3 Technology, 3-3/4": Home Improvement
Persimmoncreek-farmer
