COB's '89 Pickup 2WD
Couple years have passed, picture dump
Pickemup truck!
A grill and a smoker
222k
Foggy
4Runner tailgate
Isuzu 3.5L engine
Flat tire, 14” lag bolt
Free hankooks and matching spare rim.
Tucker Tire
Hankooks mounted… lil big at 235/65/16 (came from a ford transit)
Thule roof top tent
E-bike
227k
560SEC
3rd gen 4r partout
POR 15 new tie rods and ball joints (plus some 4x4 parts for my 90 2-door 4Runner)
Upper ball joints, outer tie rod ends
Backed into by van... RIP bumper.
My buddy's trailer, we loaded it up and took it to his place to get the rest of the front end done.
Begin front end rebuild
Energy Suspension polyurethane sway bar bushings
555 inner and outer tie rod ends
Versus old tie rods
Energy Suspension strut rod bushings
Original upper control arm bushings
Upper control arm with bushing removed, rubber only
Upper control arms with new Energy Suspension control arm bushings
Control arm bushings greased and installed, new ball joint
Both sides complete with new bushings and ball joints
Installed in truck
Ball joint torqued
Lower control arm removed, inner sleeve and bushing removed, outer shell metal intact
New bushing with original metal installed, arm installed
New lower ball joint in place
Idler arm disassembled, new rubber seal and OEM bushings (sorry didn't take pics, hands were too greasy)
Spindle installed
New sway bar end link bushings
Strut rods installed with new bushings
Back up and ready for more work and shenanigans
Matching spare wheel
OC Yota Nights
Now that the front bumper got smacked by a van, I’m over this. The 4Runner front end has been sitting in storage for a while, let’s get it over with. Just my luck that the damn gardener stepped on the driver fender too.
Stripped down
Core support removed, original fenders and dented bumper all removed
4Runner core support cleaned up and ready for mockup
Test fit went well, core support installed with 4runner headlights
4Runner fenders fitted
4Runner grill and clear corner lights installed
4Runner bumper painted. It was too cold out so the paint didn’t come out too well. Gonna have to repaint it.
Dual Hella horns
Camp Pendleton Vista Point
Upon driving the truck and immediately realizing how shitty the OEM 2nd gen 4Runner headlights are, I bought some brighter bulbs, Sylvania Silverstar Ultra. Still could not see a damn thing. They are ON in this image. Holy shit.
At night. I had to drive with the high beams on just to see. I’ve heard these housings were bad, but DAMN.
Well, screw this. LED headlamps it is. $30 on Amazon for these Rimthin LED’s.
Compared to the Silverstar Ultras. Night and day difference.
LED corner lights.
LED Reverse and tail lights
Misc pics + with my friend Ed’s Tacoma, which we also 4Runner swapped with a 3rd gen
OC Yota Nights with our old friend <!-- BEGIN TEMPLATE: dbtech_usertag_mention --> @driffter33 <!-- END TEMPLATE: dbtech_usertag_mention -->
Some nice truck loads
First time hauling a motorcycle
Broken tailgate handle replaced with metal handle
Scored a set of Continental Extreme Contact 225/50/16
Little more scenic view, 4runner swapped trucks
New dash designs dash cover, black carpet, needs more velcro but a good fit
New LED bulbs for map lights
Replacement upper radiator hose and t-bolt clamps. Cleaned up battery clamps. New exhaust manifold gasket (lower donut gaskets)
Replacement speedometer gear 33403-19235, 10/35 tooth
Versus original 11/31 tooth
Installed into VSS with new O-ring. Speedo nearly perfect now for the 225/50/16 on the 4Runner SR5 cluster.
Ed gave me his old Snugtop tonneau cover which I plan to respray and install later on.
Pics with ed’s Taco
Misc pics
New idler pulley bearing for power steering
Koyo 6204RS
Remove clip and press out
Original bearing removed
New bearing in place ready to press in
32mm socket worked great
Clip reinstalled and ready to go back in the truck
Decided to ditch the 50lb+ Fey diamond step bumper
Had to cut off the plate hardware
Plate installed with new hardware direct to bed
Changed the exhaust manifold gaskets and of course one of the nuts decided it wanted nothing to do with coming off. I ended up having to cut the stud off and then installed a Nickson clamp-a-stud because I just don’t feel like pulling out the manifold. It’ll probably get changed out for an LCE street header someday so this’ll do til then. This clamp is a pretty cool design and it was actually really easy to use and install. No leaks and worked great.
Next up is a Wolfbox dash cam setup, got it on sale for $58 on eBay
My friend Ed gave me a license plate mount to fit the rear camera, I modified it a bit and then drilled a hole into the camera mount to mount it direct. Then I used a bolt from a MK3 Supra gauge cluster to tie it all together. I’ll get it installed and post pics later.
Wires for wolf box fished through headliner
Mirror finished and installed
Rear camera installed
Acquired a new AISIN CKT-022 clutch kit, free! Someone bought it for a 3.0 4Runner and didn’t realize it was a 22R-E kit.
I’ve had a lightweight LCE flywheel sitting around for a few years, test fit the pressure plate and it fits perfect.
Back in 2021, I had acquired the 4Runner front end from a friend of mine, but my gardener thought the driver fender looked like a mighty fine step.
<iframe width="560" height="480" src="https://www.youtube.com/embed/qJcF7y6vLtU?si=J8JE4vyR8_Q9ntK0" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen=""></iframe>
I wanted to do the front end swap pretty badly so I ended up pulling out the giant dent as best as I could, but it was still pretty messed up. Finally saw a white 4Runner pop up on the Pick Your Part app and dropped by to grab a driver fender.
I couldn’t wait and installed it the same day.
Fresh wash
Even cleaned the area behind the fuel door
OC Yota Nights
Finally tracked down the owner of my favorite mini truck, got to talking and he showed me some tricks on how to mount a set of 4Runner headlights on an early 4Runner/pickup core support. I plan to do the same on my 90 2-door. He sold me a 92-95 4Runner grill for a killer price.
Picked up a center console from a 95 4Runner that did not have rear heat. Here's the parts truck
Much more space inside. Here it is compared to the previous console from a rear heat equipped vehicle.
Lid moved over
Installed
