Compress rear shocks in order to tighten?
Luke325i
I'm assuming you already have the lower shock mount bolt threaded on. If so, did you try jacking the axle up to compress the shocks enough to get the nut threaded?
It might be too late for this part, but the easiest way to install rear shocks is in this order:
1. Mount bottom shock bolt
2. Cut shock strap and let it slowly decompress into the top mount
3. Secure top mount
If that's no longer possible, you'll want to compress the shock by carefully jacking up the side of the axle you are working on. Doesn't need to be much.
I can re-compress them easy... Ive tried it with lower connected, and lower disconnected
I think im going to have to use a jack, you're right
Yeah and once you have the nuts started on both side, bring the vehicle back down on the ground and then finish tightening it down. You'll have a lot more thread to work with then.
brendaglores
